Lower tire profile for 04 coupe (18in/brembo)
Old Aug 17, 2008 | 06:20 PM
vijet44's Avatar
Hey guys,
I need your expertise on going for a lower profile for the rear fitment. Would a 245/40/18 tire be better or for worse on the vehicle? My main concern is road noise and longer tread life, may see a bit contradictory but just wanted to get some thoughts....thanks!
Old Aug 17, 2008 | 06:49 PM
drjonck's Avatar
I don't think your going to notice any difference from a change that small. If you're looking to lower road noise, that's primarily a function of tread pattern, and I'd expect harder rubber (for longer tread life) to be noisier. You'll have to take some rides in G's with tires rated higher in tread life than the ones you're on now and decide how much noise you can tolerate. I'm currently on Michelin PS2's, 275/40 18's on the rear, 245's in front. Road noise has never been an issue. My 3" Greddy TT exhaust pretty much covers it.
Old Aug 17, 2008 | 07:29 PM
Gilley's Avatar
Use this tire calculator and you can see the difference. http://www.rims-n-tires.com/rt_specs.jsp
The 245/40/18 in an inch less in diameter than the 245/45/18. I wouldn't use the 245/40.
If you go to a wider rear tire, then a 40 series tire may be appropriate.
Old Aug 18, 2008 | 01:45 AM
vijet44's Avatar
You guys are great...much obliged.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Kal Hamm
Jul 24, 2015 08:55 AM
