275/30/19 on a 8.5 wheel?
Old Aug 22, 2008 | 05:47 PM
Jeff92se's Avatar
Red Card Crew
Very few wheels come in 9" anyways, 9.5" is usually the most commonly quoted minimum width for a 275
I ran two more tire specs for that size and it comes up with 9" min. Regardless of what's the common wheel width, 9" seems to be the spec'd min. for that size.
Which is still wider than 8.5" of course.
Old Aug 22, 2008 | 05:48 PM
redlude97's Avatar
Originally Posted by JOKER
Here is my current setup.
Front. 245/35/19
Tire diameter (inches) =25.751968503937007
Tire section width (inches) =9.645669291338583
Tire sidewall (inches) = 3.375984251968504
Rear. 255/40/19
Tire diameter (inches) =27.031496062992126
Tire section width (inches) =10.039370078740157
Tire sidewall (inches) = 4.015748031496063
Tires that I'm asking about (rear)
275/30/19
Tire diameter (inches) =25.496062992125985
Tire section width (inches) =10.826771653543307
Tire sidewall (inches) = 3.248031496062992
it is a little smaller then front.
U think it's gonna make a big diff?
Your rear shouldn't even be the SAME size as your front, it should be significantly taller. Your previous setup is perfect, why change that?
JOKER's Avatar
CLUB MODERATOR
there is nothing wrong with having a little tire lip
Old Aug 22, 2008 | 05:49 PM
JOKER's Avatar
CLUB MODERATOR
Cuz Obana said.........."It's time for a change"
Old Aug 22, 2008 | 05:50 PM
redlude97's Avatar
A change for the worse....
Old Aug 22, 2008 | 05:53 PM
JOKER's Avatar
CLUB MODERATOR
that's what I thought.
So I'm not voting for him.
Old Aug 22, 2008 | 05:54 PM
06g35meister's Avatar
35 profile is the correct height for the VDC to be accurate and ABD to work
also thats what i have
Old Aug 23, 2008 | 03:04 PM
FlyingLumpia's Avatar
Joker just sell me your wheels for 500 bucks and get some new ones.
Old Aug 23, 2008 | 03:29 PM
AZ VQ35's Avatar
You'll Be alright. I just upgraded to 19" RAYS wheels, Before that I had the Stock 18's 245-front 275-rear Had no problems AT ALL.
Old Aug 24, 2008 | 04:31 AM
Triple8Sol's Avatar
Jokes, google a tire calculator. Learn to use it. Stop posting these threads...you're making us Northwesterners look bad.
Old Aug 25, 2008 | 01:16 AM
JOKER's Avatar
CLUB MODERATOR
WTF man.
Screw you.
Look at my other post.
I posted **** load of numbers how does that make "us" look bad or like I need a tire calculator.
I'm just asking if anyone tried it and if it was any good.
BTW. If any of you got the Idea that we Northwesterns look bad it's prolly cuz ya all been looking at Titos pictures.
rest of us are handsome.
Old Aug 25, 2008 | 09:49 AM
trey.hutcheson's Avatar
That is a *short* tire. That's gonna knock your speedo out of whack by 4.6%. However, it will give you shorter gearing. With those tires, you'll have the equivalent final drive to that of the 07/08 sedan(3.69).
Old Aug 25, 2008 | 10:00 AM
twin001's Avatar
Front. 245/35/19
Rear. 255/40/19
275/30/19
Thanks for carrying the decimal out to the fifteenth place
No but really, you should look into a 275/35/19 rear tire if you want to go that wide. I know there are plenty of people on this board that have put a 275 on the rear and haven't had any problems yet. I thought about going 275's but went 255/40 instead. If you do go with the 275/30's you may want to see if anyone can mount it w/o the TPMS getting in the way.
Let us know how the Vredestein's work, I am now having buyers remorse for getting the Falken FK452's over the Vredestein Sessenta.
Old Aug 25, 2008 | 11:59 AM
JOKER's Avatar
CLUB MODERATOR
I don't have TPMS I sold them when I sold my OEM 19s
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
mryogi
Aug 14, 2015 07:58 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
