hub ring question
Old Sep 2, 2008 | 09:00 PM
gtrefever's Avatar
hub ring question
i have wed farmas m-revolts do i need hub rings??? idk flame me i know its a noob question =(.
Old Sep 2, 2008 | 09:06 PM
OH6 G35's Avatar
YES!
Old Sep 3, 2008 | 01:28 AM
az1anbeethoven's Avatar
lol, yes...unless they are hubcentric, which i highly highly doubt
Old Sep 3, 2008 | 01:36 AM
gtrefever's Avatar
since ima run spacers which some have hub rings i wouldnt have anything to worry about right?
Old Sep 3, 2008 | 09:29 AM
Boston's Avatar
^you'll still need a hub ring for the the wheel. You're wheel spacer basically replaces the hub. The hub centric ring will seat the wheel properly on the spacer.
Old Sep 3, 2008 | 12:04 PM
gtrefever's Avatar
thank you, whats the best brand of the hub ring?
Old Sep 3, 2008 | 12:46 PM
Boston's Avatar
They vary in material. Rays has their own for aluminum wheels. Keep in mind not to mix metals as it will lead to corrosion. Ebay has a listing for G35 hubcentric rings that are polycarbonite rings. I've run them on another car and they held up well and serve the purpose of seating the wheel on the hub. I think they go for $10 for a set. Hub bore is 66.1
Old Sep 3, 2008 | 02:18 PM
gtrefever's Avatar
thank you boston, so the ones on ebay are good? would i need to use a certain spacer? i was gonna go with ichiba spacers.
Old Sep 3, 2008 | 03:57 PM
Boston's Avatar
the wheel spacer from a hub size will be the same bore as the OEM hub which is 66.1. Look for that size in the Ebay listing. I'm pretty sure if you search G35 hubcentric ring, it will come up.
Old Sep 3, 2008 | 04:10 PM
Boston's Avatar
Check this:
http://cgi.ebay.com/ebaymotors/G35-G...spagenameZWDVW
Old Nov 4, 2008 | 02:10 PM
O HELLA OEM's Avatar
you guys recommend hubcentric rings for OEM 18's?
Old Nov 4, 2008 | 02:20 PM
the OEM rims are already hubcentric
Old Nov 4, 2008 | 03:59 PM
^oh haha thanks
Cajuncowboy
Jun 21, 2021 09:47 AM
obender66
18 Inch
Mar 13, 2016 12:20 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
papo020
Jul 17, 2015 10:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
