widest tire for a 20inch rim
Old Sep 5, 2008 | 07:32 PM
ngarcia1983's Avatar
HI everyone,
i want to know how wide can go on a 20 inch non staggered rim.
im considering 275/40/20 or 275/45/20 in the rear of my 03 g35.
does this look good
thanks
Old Sep 5, 2008 | 07:37 PM
chenG35's Avatar
Depends on your rim width, below is the chart for Michelin PS2 for example:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
You can see 275/45/20 fits 8.5-10.5" rim
Btw i think 275/45/20 is wayy to thick, they're gonna look like drag radials. you prolly want 275/35/20.
Old Sep 5, 2008 | 07:39 PM
redlude97's Avatar
we need more information. Do you have a coupe or sedan? How wide is the wheel? Offset? Alignment settings?
Old Sep 5, 2008 | 08:13 PM
i have a coupe, and i have no idea about the alignment settings, but it has about one inch spacers and the rim must be 8.5 inch width. as previous member stated above
Old Sep 5, 2008 | 08:24 PM
redlude97's Avatar
you should be running 245 or 255/35/20 on that sized wheel. IMO you shouldn't even run those width wheels in the rear, its an awful size for an aftermarket wheel. You should not install a 275 on there either
Old Sep 5, 2008 | 08:58 PM
GreenGoblin's Avatar
The goblin resurrection
ya what wheel is that with a 8.5 in the rear
Old Sep 8, 2008 | 05:30 PM
SIN3's Avatar
20x8.5 245.40.20 or 255.40.20 i am not a fan of rubber so i would go with a 30 series but thast just me.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Jussumman
Dec 22, 2015 10:23 AM
Fire0nic3
Aug 31, 2015 03:18 PM
BlackGee35
Jul 31, 2015 11:04 AM
