Tire/Rim weight
Old Sep 16, 2008 | 10:05 PM
Darkstar752's Avatar
Tire/Rim weight
How siginificant is it? Like how much of a difference does 18lb rims make vs. 22lb rims and so on?
Also, how much do the OEM 19" weigh?
Thanks in advance
Old Sep 16, 2008 | 11:48 PM
eljoker's Avatar
i always wanted to know the same thing and also if aftermarket rims made any diffrance compaired to stock
Old Sep 17, 2008 | 12:24 AM
gimmeabeer's Avatar
Thanks in advance
Not real sure how much the coupe rims weigh... However for your other question, I have heard that losing seven pounds is about the same as gaining one horsepower.
Old Sep 17, 2008 | 07:04 AM
Yea, I'm just trying to figure this out. I think it's different than the total weight, but I'm not sure. If it's total weight having 16 more lbs. really isn't going to matter to me.
Old Sep 17, 2008 | 09:10 AM
idrive_MD's Avatar
it counts for bragging rights on the streets...in track applications its more of a "every ounce counts" issue.
Heavy wheels can be felt on the street, especially if your OEM wheels arent too heavy to begin with. You'll get sluggish starts and also see a decrease in braking if the wheels are heavy enough.
Also say your OEM 18" wheel and tire combo weights 45-lbs (25lb tire weight, 20lb wheels) and your 20" aftermarket set weights 55-lbs (25lb wheels, 30lb tires), you've added 40 extra pounds to your car, or more importantly 40lbs of extra rotational mass that you must now speed up or slow down.
for the everyday person, it may not matter and they're just happy they have cool wheels now, but for someone slightly concerned with perfomance it should be something worth keeping in mind.
Old Sep 17, 2008 | 05:11 PM
Jeff92se's Avatar
Red Card Crew
OEM coupe 18s weigh about 24-26lbs. The oem Michelins weigh about 22-24 lbs.
When I went from my oem 17s (sedan non-sport) to the coupe 19s, it made a noticable difference. And these oem 19s are forged. Getting cast 19s or 20s would murder the acceleration.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
5150DS
Sep 26, 2015 07:47 PM
PZ06G
Aug 27, 2015 06:11 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
