People with 20s chime in!
Old Sep 25, 2008 | 09:27 PM
hollisterguyo7's Avatar
Cool People with 20s chime in!
im gonna do the 275-30-20 in the rear n 235-35-19 in the front with some tein springs how often will i need to replace my back tires??? and how bad will it rub?? even with a camber kit...
Old Sep 26, 2008 | 01:56 AM
Nismoboy's Avatar
well it depends on so many things.. your driving style.. what kind of tires you buy.. how you maintain it also...
as far as rubbing... that depends on your wheel width and offsets, etc
and as far as camber... some people get lucky and dont need it.. some get the front camber arms and rear bolts.. with the tein, it depends if your goin to get the h.techs or the s.techs?? or are you talking coilovers??
with all this info.. i'm sure somebody can give you a better answer to your questions
Old Sep 26, 2008 | 02:15 AM
jjyellow's Avatar
Need more info on rims
Old Sep 26, 2008 | 02:31 AM
jserman's Avatar
your not going to rub with a 275 on the rear unless you have some messed up offset rims.... and why 19's in the front???? go 20's on all 4 corners
Old Sep 26, 2008 | 02:52 AM
ShanesG's Avatar
yeah we need the rim info to determine if they will rub. And +1 whay the 19's in front?
Old Sep 26, 2008 | 03:04 AM
daE_35's Avatar
I'm having trouble as well with what I should go with myself..I wanan go 20s but Im dropped on H techs and I'm not really feeling the fender rolling thing. If I do go with 20's I will be running 245 in the front and 275 in the back..what offset should I get then if I do that? to not cause rubbing.
Old Sep 26, 2008 | 03:05 AM
ShanesG's Avatar
what size width in the rear for the wheels?
Old Sep 26, 2008 | 03:35 AM
jserman's Avatar
Just some info for you guys I have Sevas S22 20x10 rear rim with +25 offset and I am running a 285/30 rear tire lowered on NF210 350Z springs (1.8in of total drop) and I don't rub
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
DRG35R
Sep 16, 2015 05:33 AM
