What are the reasons for needing Spacers?
Old Sep 26, 2008 | 08:12 PM
hipi2002's Avatar
I have an 06 OB Sedan, and would like to know when would they would be needed. I'm looking more and more into purchasing mrr hr-2s and some people say spacers are needed and some either don't have them or know if they are needed. I would like to know so that it's not something I need when I finally go to put them on.
Old Sep 26, 2008 | 08:29 PM
NathanJax's Avatar
..... I WIN .....
offset of the rims won't clear brakes...
Looks...
I'm not an expert so I know others will chime in...
Old Sep 26, 2008 | 08:38 PM
alphamatt's Avatar
it depends on the offset of the wheel you get to know whether or not you would need spacers, you can get a large (in width) wheel with a low offset like +15 and it will sit flush, but if that same wheel had a +43 offset it will tuck in, offset is the mm from the center wheel line, a + offset while yield less lip than a - offset, but it comes down to whether your car can fit it.
if you purchased a sedans wheels with a +45 offset, adding 20mm hubcentric spacers would yield a +25 offset for the wheel giving it a much better look aesthetically, necessary? only in a condition where the brake calipers are too fat the wheel cannot fit, in this case spacers can solve the problem.
Get a fat wheel with a good offset and dont worry about spacers
Old Sep 26, 2008 | 08:43 PM
hipi2002's Avatar
So do most of the coupe Guys get the spacers?
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
