Will 225/55/17 be an issue
Old Sep 30, 2008 | 03:48 PM
M_1313's Avatar
Hi,
I'm presently shopping for winter tire and i was wondering will 225/55/17 all around will be a issue on a 2006 g35coupe with the OEM 19 normally.
Thanks
Old Sep 30, 2008 | 03:58 PM
redlude97's Avatar
a staggered setup would be ideal, but people have run this setup on a coupe successfully.
Old Sep 30, 2008 | 04:03 PM
M_1313's Avatar
Thanks, i know a staggered setup would be ideal but i can save 200$ with this size all around
Old Sep 30, 2008 | 04:14 PM
ttrank's Avatar
Grocery getter
^+1
I believe a 225/50 is closer to the oem size but as long as you go the same size all around, you will be ok.
Old Oct 7, 2008 | 10:12 PM
repin_LB's Avatar
if running these 225/50/18 would these be okay even with the g35 s-tech drop?
Originally Posted by ttrank
^+1
Old Oct 8, 2008 | 02:30 PM
nikst's Avatar
tire calc says for R17
front - 225/50/17
rear - 225/55/17
I face the same problem for the coming winter...
Old Aug 30, 2012 | 05:06 PM
RKP's Avatar
RKP
Im shopping for winter tires for my 2007 Infiniti G35 Coupe. The car originally came with a staggered set - 225/45/R18 Front - 245/45/R18 Rear.
I was planning to buy a set of winter rims with tires that are staggered - Front 225/50/R17 and Rear 225/55/R17.
Wondering if these would fit my G35 and if it would affect my RPM and my ABS?
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
