Spacers & Extended Studs - going from 15mm to 20mm
Old Sep 30, 2008 | 10:24 PM
Calvin's Avatar
Overglorified Altima
I currently have 15mm Ichiba v1 spacers up front with the included extended studs installed. I want to move to 20mm spacers, but do I need to change out the studs again? Are the 20mm spacer studs longer than the 15mm spacer studs? Anyone know?
Thanks.
Old Sep 30, 2008 | 11:07 PM
redlude97's Avatar
all 25mm spacers are bolt on, so the longer 15mm studs will extend past the spacer. it will depend on if the wheels have a space between the stud holes.
Old Sep 30, 2008 | 11:10 PM
Calvin's Avatar
What about 20mm?
Old Oct 1, 2008 | 10:20 PM
tdm racer's Avatar
20 mm ichiba spacers are thinner than the 25's and thus the original studs on your hubs will stick out a bit... So long as there is enough space in the indentations between the spacers studs for the original hub studs to fit, you're in good shape.
Old Oct 2, 2008 | 12:16 AM
Nismoboy's Avatar
Thanks.
wow... seems like no one has any idea what you're trying to ask hahah but you're in luck.. i know exactly what you're saying...
you're saying "you have extended wheel studs that came with the 15mm ichiba spacers...you pressed those in your hubs already... but now you wanna put on 20mm ichiba spacers.. and you wanna know if the extended studs that came with 15mm kit that you pressed in already are long enough to accomdate the 20mm spacers right??"
well the only answer i got for you, is probably not the greatest lol, but i was told by someone at discount.. as long as you can get 7 full turns on your lugs.. you will be fine
Old Oct 2, 2008 | 12:54 AM
Calvin's Avatar
that's exactly what i want to know.
now, who knows if i can get 7 full turns with 20mm spacers on the extended studs that came with the 15mm spacers?
Old Oct 2, 2008 | 01:11 AM
k67p67's Avatar
Maybe I'm not thinking about it correctly but...wouldn't you be more concerned that the extended studs from the 15mm spacers might be too long for the 20mm spacers? If so, wouldn't they protrude past the new spacer and contact the pad of the wheels?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
