Tire Pressure Sensor
Old May 18, 2004 | 08:54 PM
08G37TX's Avatar
Has anyone with an 04 with the Tire Pressure Sensor swapped out your rims for the 18's....what all is involved with the swap out?
Do all 04's have the tire pressure sensor?
Old May 19, 2004 | 01:47 PM
g35don40's Avatar
Re: Tire Pressure Sensor
Answer to your second question,
Yes all 04's have the tire sensors.
2004 6mt Coupe Red/Black/4pc-Aero/Premium/BSM/ with seating for 5
Old May 19, 2004 | 09:19 PM
dave's Avatar
Well, it depends on exactly what you want...
You said swap out rims. If you replace your current rims with a new set, it should be fairly straight forward to remove the sensors from your current rims and install them on the new rims. Check with your retailer to make sure the sensors will fit in your new rims.
If you want to have two sets of rims, it gets more complicated. You can buy a second set of sensors for ~$400 each ($1600 for all 4). And then if you did that, you would still have to take it to the dealer to get the sensors "registered" whenever you swap rims.
If you choose to get new rims and NOT use tire pressure sensors in them, the car doesn't complain too much about not haviing the sensors.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
