Wheel spacer for OEM 19
Old Oct 8, 2008 | 06:28 PM
irishsig's Avatar
Hey cool, it's the 1st time a pic of my G has been referenced in a post. Yeah the front is slightly tucked but I'm hoping an alignment will help with that a little.
Old Oct 16, 2008 | 09:10 AM
Dan_G's Avatar
good info... thanks, how about if you are dropped about 1" on a coupe? planning on getting my OE 19s powdercoated and planning on suspension afterwards
Old Oct 16, 2008 | 05:39 PM
jlin615's Avatar
I'm running Project Kics 20mm/25mm for four months now, no problem at all. Except dealers get confused when I take the car in for service.
BTW, I'm putting them up for sale next month. Moving to rims.
Old Oct 17, 2008 | 12:10 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
go with the Eibach hubcentric spacers. studs already attached as is the hub centric rings...no worries. I would go with 20/25 F and 25/30 R. either setup will look much better than stock. just depends upon how aggressive you want to be. I ran the 20F 25R Eibach with my stockers in winter months for approx. 10K miles. never had any issues. cheers!
Old Oct 17, 2008 | 12:21 PM
RST531's Avatar
i cant find a place that has Eibach hubcentric spacers in 30mm. does Eibach make that size?
Old Oct 17, 2008 | 01:18 PM
LightsOut's Avatar
SIETESG
they do. try autoanything.com
but look under 350z, thats where i bought my spacers from or call them
Old Oct 17, 2008 | 01:25 PM
RST531's Avatar
i just checked and highest is 25mm.
Old Oct 17, 2008 | 02:07 PM
LightsOut's Avatar
SIETESG
just do what im doing 15/20 then 245 front 255 rear
Old Oct 17, 2008 | 02:11 PM
RST531's Avatar
thanks. but i just wanted to check the price for them since they are hubcentric and studs inculded.
Old Oct 17, 2008 | 02:44 PM
LightsOut's Avatar
SIETESG
well if you ever get ebiach part type number u wanna get is Type 4.
those are the one's with the studs built into the hub
Old Oct 17, 2008 | 03:39 PM
DRG35R's Avatar
20 Year Member
go 20/25 or 25/25, but definitely get the Eibach. no worries with these. you will not be disappointed.
Old Oct 17, 2008 | 03:43 PM
surfwb86's Avatar
i have project kics 15/20mm on my stock 19s, also bought hub centric rings to go with them. They look great and compliment my springs very well. A must have for those sticking with the stock rims.
No problems here...
Old Oct 17, 2008 | 03:49 PM
DRG35R's Avatar
20 Year Member
no offense, but how do you see them since they are behind your wheel hubs and how do they compliment your springs? just wanted to know where you were coming from with this.
Old Oct 17, 2008 | 04:00 PM
surfwb86's Avatar
I'm referring to the wider stance of the car thus the purpose of getting spacers. Lowered cars on stock rims dont look right to me because the wheels are sucked in so far from the factory. With the rims being flush it looks ten times better on a lowered car.
Old Oct 17, 2008 | 04:07 PM
  #30
jlin615's Avatar
I think he meant "match" with the springs
