Wheel spacer for OEM 19
Old Oct 8, 2008 | 12:46 AM
kenempireex's Avatar
I am looking forward to get some spacer for my OEM 19. I am looking at project Kic 15mm, 20mm, but i heard bad things about them.
Old Oct 8, 2008 | 05:02 AM
Skaterbasist's Avatar
Retired SuperMod
Bad things as in what?
Old Oct 8, 2008 | 10:45 AM
I heard 2/5 studs broke from one of the user with Project Kic.
How about that Iciaba v2 spacer? It seems pretty popular all the sudden.
Should I go for 20mm, 25mm setup instead?
Old Oct 8, 2008 | 11:04 AM
Calvin's Avatar
Overglorified Altima
People will have poor experience with all brands, whether you hear about them or not.
My friend just picked up a set of Ichiba V2 25mm spacers. They look nice.
I would go 25mm front and 30mm rear.
For reference, here is 20 front 25 rear.
Still tucked...
Old Oct 8, 2008 | 11:15 AM
Is it really bad for the wheel bearing to go for wheel spacer?
Old Oct 8, 2008 | 11:56 AM
Retired SuperMod
^ You should be fine as long as they're hub-centric.
Old Oct 8, 2008 | 12:04 PM
LightsOut's Avatar
SIETESG
i got eibach spacer with built in studs. been using for 4 months now with no problems.
Old Oct 8, 2008 | 12:09 PM
SIN3's Avatar
i have project kics on my car for over a year now, i dont do any crazy driving but as you can see my suspension is cambered to hell and cambering puts extra strain on all parts. mine are still fine..
PK are made by rays, rays makes volks, and that name speaks for itself... i wouldnt run any other spacers other than PK
good luck
Old Oct 8, 2008 | 12:30 PM
so, I should go for Project Kic 20mm and 25mm with hubcentric ring?
Old Oct 8, 2008 | 12:33 PM
Calvin's Avatar
25 front and rear
Old Oct 8, 2008 | 12:38 PM
Originally Posted by Calvin
25 front and rear
Isn't 25mm front too much? Where should I buy these from?
Old Oct 8, 2008 | 12:44 PM
Calvin's Avatar
look at the picture i posted above...20 front 25 rear. it's still tucked.
i suggest 25 front 30 rear, but if you must go kics then 25 front and rear.
try our forum sponsors.
Old Oct 8, 2008 | 02:51 PM
LightsOut's Avatar
SIETESG
i went 15/20 cause i plan on getting wider tires.
Old Oct 8, 2008 | 04:56 PM
HenryLee's Avatar
Trust Clavin.. you should go for 25 front and 30 rear. I've searched previously and saw that 20/25 setup is still tucked. 25/25 will look better but 25/30 would look flushed.
Old Oct 8, 2008 | 05:06 PM
mt7rabbit's Avatar
true 20f, 25r is still tucked a bit but looks good.
