R17 wheels: basic parameters & offset question
Old Oct 8, 2008 | 03:15 PM
nikst's Avatar
Now I have stock R18 wheels on my `03 Coupe and I`m planning to buy R17 wheels for the coming winter.
Read some sources & this topic https://g35driver.com/forums/wheels-...s-offsets.html
The parameters for R17 wheels differ!
There are the following:
1. Front & Rear: 17"x7" +40mm offset 5x114.3mm (5x4.5in) bolt pattern (aka PCD)
2. Front: 17"x7.5" +30mm offset, Rear: 17"x8" +33mm offset
3. Front & Rear: 17"x7" (+45mm)
4. Some sites gives 17"x7.5" +42mm offset
The tires I`m planning to install are
225/50/R17 front & rear
225/50/R17 front & 225/55/R17 rear
So what is the best choice? Wheels with what offset would be better?
Can anybody help me with this question?
Old Oct 8, 2008 | 04:19 PM
redlude97's Avatar
You want the staggered coupe setup, with the staggered tire setup 225/50/17 and 225/55/17 or 225/50/17 & 235/50/17. The offsets on the 17x7 sedan wheels will work, but will be quite sunken in. I know from experience
Old Oct 9, 2008 | 06:58 PM
jmf408's Avatar
Will G35 Coupe staggered tire setup on work on a Sedan?
Similar question, but opposite situation. I have located a set of winter tires w/rims that were purhased for a g35 coupe, and before I buy them for my sedan, I'd like to know if they will cause problems other than speedo error. I have a 2005 6MT sedan with the 18" rims. The sizes of the winter tire setup are 225/45VR18 (x2 front) and 245/45VR18 (x2 rear) on 18" ASA JH3 wheels.
Any help or insight is appreciated.
J
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
