265/295 on Volk GT-S 9.5/10.5 -- Help with fitment
Old Oct 11, 2008 | 01:28 AM
Dem1K's Avatar
Exclamation 265/295 on Volk GT-S 9.5/10.5 -- Help with fitment
The wheels:
Volk GT-S
F-19x9.5 +17
R-19.10.5 +18
The tires:
F-265/30/19
R-295/30/19
I'm dropped on 350z S-techs, and I'm thinking of picking these up. I know I'll have to get the fenders rolled, but will it be cool besides that? Also, how will this affect my current ride (aka, suspension, turning radius, acceleration/speed, etc etc..). Any help would be appreciated here, thanks!
`John
Old Oct 11, 2008 | 01:30 AM
r0csfinest's Avatar
youll be fine with just rolled fenders
Old Oct 11, 2008 | 03:37 AM
Dem1K's Avatar
and how about acceleration/speed, handling, turning radius, etc..?
Old Oct 11, 2008 | 12:05 PM
r0csfinest's Avatar
Your good I'm running basically the same setup cept slammed on coils
Old Oct 11, 2008 | 12:38 PM
nghiars's Avatar
the s techs dont drop it much(IMO) and you should fit fine with rolled fenders.. rims are lighter than stock(size for size) but since these are bigger and forged, weights likely to be a wash so acceleration should be the same. Turning radius changes are neglible and handling should improve since you will have a lower center of gravity.
Old Oct 11, 2008 | 03:07 PM
Dem1K's Avatar
Well reason I asked is because I'm rollin' on 245/35/19 and 245/40/19 on the OEM 19s right now. Those are relatively light as is. Plus, factory front is 225, and jumping to 265 is quite a bit, so I figured it would cut down the turning radius some. Also, I wasn't sure if the 295s in the rear would be too much meat, therefore slowing me down.
edit: apparently tire size doesn't really affect turning radius much...
Old Oct 11, 2008 | 10:28 PM
MPK1232's Avatar
i have 285/35/19 on the rears and i was rubbing big time. i ended up having to roll my fenders on stock suspension. i would recommend 275's before slapping those wheels on, especially with your drop.
Old Oct 11, 2008 | 11:54 PM
r0csfinest's Avatar
im on 295/30/19 rear with rolled fenders and slammed on coils and have no problems.
Old Oct 12, 2008 | 02:40 AM
Triple8Sol's Avatar
You'll be fine. Those fit easier than a 255/35/ & 285/35 combo since your setup is actually smaller in diameter.
Old Oct 12, 2008 | 05:12 PM
Dem1K's Avatar
does that setup throw off the speedo much?
Old Oct 12, 2008 | 05:40 PM
SFLG35's Avatar
FGC President
just stick with 245 35 19 and 275 35 19 and you will have no problems
why do you want a 265 35 in the front anyways. thats a huge tire for a 9.5
Old Oct 12, 2008 | 05:52 PM
Dem1K's Avatar
the wheels come with these tires
Old Oct 12, 2008 | 05:54 PM
SFLG35's Avatar
FGC President
ah
well then whn you wear them out, i would just stick with a 245 275 combo.
Old Oct 12, 2008 | 09:22 PM
redlude97's Avatar
great sizes, much better than sticking 245/275's on those widths
Old Oct 12, 2008 | 09:26 PM
Dem1K's Avatar
Thanks guys.
Redlude, any negatives about going w/ these sizes? And will just rolling the rears work out? I haven't gotten an alignment done yet since I put the springs on about 10 days ago, so should I wait until I put these on as well? Thanks.
`John
