Wheel spacers help
Old Oct 29, 2008 | 03:23 AM
GreyGoose35's Avatar
Wheel spacers help
what size wheel spacer's do you guys suggest?
Old Oct 29, 2008 | 03:50 AM
Polishthrust's Avatar
I believe that most people prefer 15mm front and 20mm back on oem 19s for the coupe. It depends on the rims u have.
Old Oct 29, 2008 | 04:21 AM
20's???
Old Oct 29, 2008 | 10:22 AM
Boston's Avatar
need to know the offsets to help with spacer size. Also lowering and camber comes into play. If you're just pushing the wheels out for a more flush look, subtract the spacer MM from the wheel offset MM
e.g. Your front wheel is 20 x 8.5 + 25 E.T. and a 15MM spacer and your new offset is +10. The further you move out the more chance you will rub during bumps or undulations in the road. You can further lower the front and add neg camber to tuck the fronts and eliminate some of the rubbing.
Old Oct 31, 2008 | 10:58 AM
UR2EZ's Avatar
i have a sedan, can i stick 25mm spacers all around on stock wheels with no camber issues??
Old Oct 31, 2008 | 02:42 PM
Boston's Avatar
^I believe 25MM were being used on OEM coupe 19's when mounted on the sedan but double check and I know there are numerous theads/ posts. As for camber, you won't have an issue unless you lower the car.
Old Nov 3, 2008 | 09:56 AM
GzUpHozDn's Avatar
Has anyone used the spacer with a coupe and the stock 19's? What thickness should be used with those if using Tein S-techs?
Old Nov 3, 2008 | 10:04 AM
mt7rabbit's Avatar
^25mm front and 30mm rear.
Old Nov 3, 2008 | 10:25 AM
GzUpHozDn's Avatar
Thnx mt7...was checkin out the other postings n saw the same...mah bad for the redundant ques...=0P but good lookin out on the response...btw do the 350Z s-techs give a lower drop than the G35 s-techs?
Old Jan 15, 2009 | 02:49 PM
Socal
does anybody in socal know where i can purchase them and get them installed. i dont want to order them off line if i dont have to???thnax
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
