275/30/20 or 285/30/20 ??
Old Nov 3, 2008 | 04:56 PM
tommy07g35's Avatar
Is there a huge difference? Looking to replace my rears only for now. This is going on a 20x10 rim. I'm planning a drop (coilovers) soon too, so I want to make sure it won't rub. Is one lower profile than the other? The reason I'm replacing the rears is b/c the rims came with 35 series tire which is a little too beefy for my taste. I'm getting these in Falken 452's to match the fronts. I've got 245/35 on the fronts which are low profile, and look very nice. Trying to match the rears now...245/35f and 275/30 r seems to be a popular combo on here...
Thanks!
Old Nov 3, 2008 | 05:07 PM
redlude97's Avatar
you should replace the front tire while you are at it since its almost an inch taller than stock
Old Nov 3, 2008 | 05:10 PM
tommy07g35's Avatar
I will, eventually, just doing the rears for now. Why do people run 35's in the fronts anyway with 30's in the back
Old Nov 3, 2008 | 05:21 PM
g35philong's Avatar
its alot cheaper to run 30s in the back, i prefer more beefier like 35s on the rears though. 35's all around makes the stance of the car more aggressive IMO. if you want to run 285/30 depending on most wheels you have to roll your fenders.
Old Nov 3, 2008 | 05:31 PM
redlude97's Avatar
Raising the car an extra inch is more aggressive?
Old Nov 3, 2008 | 05:56 PM
bigc's Avatar
Wings Nation
Thanks!
I'd recommend you go with 285s in the rear if you want to use FK 452s. They have rounded shoulders which makes a 275 look stretched on a 10" rim.
Old Nov 3, 2008 | 05:59 PM
g35philong's Avatar
^^ i know its hard to explain... makes the fronts lower than the rears, oviously you can solve the problem with coilovers but i just had springs.
Old Nov 3, 2008 | 06:25 PM
tommy07g35's Avatar
I felt like that at first but than I saw G's with thinner rears, and thought it looked better. I'm def dropping it, so what do you all think will look better and not rub w/o rolling the fenders? Check it out--this is how it looks right now.
As I keep looking at it, the rears look so much more teller than the fronts
http://www.garetstroup.com/uploads/I...607-edited.jpg
http://www.garetstroup.com/uploads/I...5/IMG_3606.JPG
http://www.garetstroup.com/uploads/I...5/IMG_3604.JPG
Oh, and from what I've found the 30 series are bit more expensive than the 35's.
Old Nov 3, 2008 | 06:29 PM
tommy07g35's Avatar
My fronts looks kind of stretched, and I think it looks good, shows off the lip a bit more. Shouldn't I just do 275's in the back to keep it looking similar?
Old Nov 3, 2008 | 08:24 PM
Triple8Sol's Avatar
Go with 285/30 in the rear. Then switch to 255/30 in the front when it's time for new tires.
Old Nov 4, 2008 | 05:59 PM
tommy07g35's Avatar
That sounds good, I was thinking about that size actually...hopefully won't have to roll my fenders.
jonnyz
May 14, 2006 12:20 AM
dgussin1
Jun 29, 2003 10:32 AM
