OEM 19s on G35x...tire question
Old Nov 19, 2008 | 12:19 PM
TheWick's Avatar
I'm going to put a set of OEM 19s on my wifes X. Would there be any issues with just running a 245/40 tire all the way around? I know they are staggered a bit but that size tire will fit on both wheels with out a problem. Am I overlooking something? Thanks
Old Nov 19, 2008 | 02:05 PM
redlude97's Avatar
You can probably get away with that, although I wouldn't rotate them. Putting a wider wheel in the front compared to the rear could lead to unusual handling characteristics. Better off finding another set of 19x8's to run in the rear, many owners would be willing to swap you their 19x8's for your 19x8.5's
Old Nov 19, 2008 | 02:19 PM
TheWick's Avatar
I hadn't even thought of that. Thanks
Old Nov 19, 2008 | 02:24 PM
CandlestickPark's Avatar
ill Sedan
I've been running 245/40s all around on OEM 19s for more than a year now, no problems here. I am lowered on Eibach Pro Kits and rub a little on the fronts on very steep inclines (only one driveway that I've driven into).
Old Nov 19, 2008 | 02:28 PM
Hotdawwgman's Avatar
They look very beautiful Marcus....
i wish i had them....
Old Nov 19, 2008 | 02:40 PM
ill Sedan
^Thanks Mark, you should pick up a set in the Marketplace
Old Nov 19, 2008 | 06:38 PM
Don@TireOption's Avatar
245/40/19 would work!
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
nervseele
Jul 17, 2015 11:21 PM
mushu
Jul 15, 2015 03:55 PM
