patch/plug a tire
Old Nov 24, 2008 | 04:57 PM
absolutg's Avatar
workin...
patch/plug a tire
so i found a nail in my 255/35/19 rear tire yesterday. it's in the middle of the tread pattern.
how effective is patching/plugging a tire for fixing this problem. i have an 800 mile road trip i'm doing friday and saturday so i need something i can count on. thanks!
Old Nov 24, 2008 | 05:47 PM
Texasscout's Avatar
It will work, but patches void the speed rating of the tire. Most likely the warranty also.
Old Nov 25, 2008 | 04:19 AM
dvsmeth0dz's Avatar
make sure your spare is inflated, just in case
Old Nov 25, 2008 | 01:01 PM
canucklehead's Avatar
patches work fine. they do them everyday. don't plug.
Old Jan 10, 2009 | 11:26 PM
pczavala's Avatar
what do you mean by voids the speed rating? any risk involved if lets say i were to track it with a patch on?
when you patch do i need to have the tire re-balanced?
Old Jan 10, 2009 | 11:34 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If the place knows what they're doing, then it'll last as long as the tire. I plug/patch tires every day. Even my own tires when need be and have never had a problem. I've gone 120+ MPH on a plug/patched tire and never had problems. If you take it to Discount/America's tire, they will ALWAYS use a plug and patch for the repair.
-GP-
Old Jan 10, 2009 | 11:36 PM
YES, the tire/wheel assembly needs to be rebalanced. The only way to perform a proper repair is to remove the tire from the wheel and patch it from the inside.
-GP-
Old Jan 10, 2009 | 11:39 PM
It is true that they void the speed rating. I've never heard of any shop voiding the warranty on a tire after being repaired, unless you had the tire patched at a different shop. But that is hardly ever the case, more often than not, customers will stay with the shop they purchased the tires from unless they have had a very bad experience.
-GP-
Old Jan 10, 2009 | 11:52 PM
Texasscout's Avatar
I didn't say it wouldn't work, what I said is that the speed rating is void once it's done. They won't guarantee that it will meet the specs for speed and temp ratings after a patch, but especially a plug.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
