17's to 19's...could i have problems?
Old May 31, 2004 | 01:05 PM
HardDriver's Avatar
My coupe has the stock 17'' wheels and tires, with 225/50/17 tires in front and 235/50/17 tires in the back. I have new 19'' wheels and tires on order, but they will be with 245/35/19 front tires and 275/35/19 rear tires. I've always heard that you need to keep the same diameter when upgrading tires for VDC, and this isn't usually a problem for people with my new tire size (I see people with those sizes on here all the time). BUT, I suddenly realized that they are all most likely upgrading from the 18'' rims. Will I have problems? Is there anything I can do, like have my ECU reset with the factory settings for coupes with the stock 18's?
Old May 31, 2004 | 01:08 PM
R2 V35's Avatar
Re: 17's to 19's...could i have problems?
As far as I know that set up is VDC Friendly. So, nothing to worry about [img]/w3timages/icons/smile.gif[/img]
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Is simplicity best or simply the easiest"
Old May 31, 2004 | 02:33 PM
axiochris's Avatar
i was in the same situation as yourself. my vdc light never goes off. my coupe is dropped with eibachs also.
http://www.eco.utexas.edu/~wayney/makingout.gif
Old May 31, 2004 | 02:51 PM
HardDriver's Avatar
Axiochris...that's not good...did you do anything to fix the problem?
Old May 31, 2004 | 06:56 PM
axiochris's Avatar
whats not good.???
i upgraded from 17s to 19s myself. everything thing is fine.
Old May 31, 2004 | 08:41 PM
HardDriver's Avatar
Ohhhhh...I'm sorry, I think I misunderstood your above post. I thought you meant that your VDC light never goes OFF (as in...it's always on!), and I didn't think that was good. Never mind, though, my bad! Thanks for your re-assurance.
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
