Want to Run 245/17/50 all around
Old Nov 25, 2008 | 12:09 PM
boise's Avatar
I have a 05 Sedan non-sport with the stock 17" wheels. I want to put on 245's all around but I am concerned with possible rubbing in the front. Has anyone done this? If I need a spacer to move them out a bit does anyone know how much.
Thanks
Old Nov 25, 2008 | 03:30 PM
Klubbheads's Avatar
245 are too wide for 7 inch stock rim. As far as rubbing goes, no u won't rub but it won't be safe at the same time. Go with 235s all around.
Old Nov 25, 2008 | 06:46 PM
boise's Avatar
I know you can put a 245/50 on a 17" wheel, you can put a 255/50 on a 17" if you want to. I just wondered if it would rub on the inside arms since it's 5mm wider on each side than a 235. I'm not quite sure how it would be dangerous.
Old Nov 25, 2008 | 06:49 PM
Klubbheads's Avatar
Ur rim width is not 17 inches, its 7.0 inches. 17 is ur rim size. On a 7.0 rim the maximur recommended size should be 235.........
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
