Installing Hawk brake pads
Old Jun 2, 2004 | 04:16 PM
KingoftheRoad1's Avatar
Plan to install both the front and rear pads this weekend. Anything out of the ordinary that I should be aware of? Some rear brakes are different from the front when removing pads. Do I need any special tool for the rear pads? Many thanks in advance.
2004 G35X
Old Jun 3, 2004 | 09:57 AM
Re: Installing Hawk brake pads
Still no replies. I guess nobody in this forum changed rear pads on thier own, all at the dealers. Come on guys, share your experience.
2004 G35X
Old Jun 3, 2004 | 10:14 AM
Catatafish's Avatar
DIY forum has detailed instructions. Make sure you tie your brake line to something with something (I use zip ties) and don't leave your calipers dangling. Wear latex gloves. Use the right tools. Torque to specs. If you don't have the specs and a torque wrench, don't do it.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5
Old Jun 3, 2004 | 04:47 PM
Catatafish, I checked twice in the DIY but I did not see anything on changing brake pads. I have done it on different cars before so I do know how. My issue is some rear brakes are different and requires special tool to push the piston back. I want to be prepared for the job. VW Passat is one of them. Is it the same to push the rear brake piston back as the front, anyone?
2004 G35X
Old Jun 4, 2004 | 02:26 AM
skaline's Avatar
Here's a DIY I found for the fronts. Still don't know about the rears. Hope this helps a little.
click me
My 350GT
jsimonk
Dec 22, 2023 03:49 PM
miata007
Aug 17, 2015 04:36 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
