Hello!
I'm looking at a set of 300zx rims for my snow tires. Will these fit my 05 x? Thanks for the help!
YY
YY
they should fit on the rears, im guessing this is a set of four of the 16x7.5 wheels and not the 16x8.5?
they'll look dated, why not just try to get something else and newer, plenty of ok looking wheels for $100 and less in sedan fitment I would think. I would suggest something in 17x7...good luck
Jeff92se
Red Card Crew
close
- Join DateMay 2005
- Locationɐʍ 'ǝlʇʇɐǝs
iTrader Positive Feedback100
iTrader Feedback Score(24)
Liked:585 Times in 498 Posts
16"s should fit the 05x as they had the small rotors also. But Z offsets are pretty big at around 40-45mm so I don't know if they will rub the strut
HI,
The thing is they are $100 with Blizzaks that have good tread left.
But no good if the offset is that big. I must keep looking...?
could always just buy them because of the deal on tires and then get better fitting 16s, you'll be able to resell the wheels for $75-$100 quickly once you get the tires off of them...i generally see them go for $25-ea on ebay
