What is A-Disk and O-Disk?? What is the difference? Need Help!
Old Dec 13, 2008 | 05:10 PM
jalilig35's Avatar
Ill be ordering some new wheels sizes are 20x9.5 +5 front 20x10.5 +5 in the rear, I want massive lip size as possible but I also want it to fit bbk. Is it the A or O disk?? What does disk mean? How do i make sure I get the biggest lip possible with bbk fitment?? Let me know please thanks
Old Dec 13, 2008 | 05:30 PM
SFLG35's Avatar
FGC President
well most likely you are talking about work wheels.
r disk means +25mm
a disk means +8mm
o disk means oem
you will need r disk fronts to clear brembos or bbk, you can use o disk rears and be fine.
you will need a disk front to clear the stock 05 brakes.
Old Dec 14, 2008 | 06:32 PM
Triple8Sol's Avatar
Depends on the particular Work wheel. O disks on some will clear the rear Brembo, and some won't. Some R disk fronts will clear, and some won't.
Old Dec 15, 2008 | 01:32 PM
jalilig35's Avatar
ok Im getting works t1s step lip +5 offset, I want the wheels to clear bbk with as much lip as possible which one do I get
Old Dec 15, 2008 | 08:59 PM
Triple8Sol's Avatar
You always need R-disk front, since it offers the most clearance. Some wheels it will fit, some it won't. T1s happens to be one that it will work on.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
