Wheel Spacer Install?
Old Jun 5, 2004 | 12:56 PM
khsonic03's Avatar
Has anyone installed wheel spacers with longer lugs BY THEMSELVES? I am trying to get a feel to see if I will need a shop to press in the new studs. I purchased the H&R 5mm spacers for the REAR of my car. I am assuming I will just have to take off the caliper and the disc and then I can access them with a hammer. Then I am not quite sure how hard it will be to put in the new studs. If this is incorrect, can someone please advise me on how they did it? Thanks.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, 19" Gram Light 57F Pro's, Hotchkis sways, Borla
Old Jun 5, 2004 | 01:00 PM
Z33RIE's Avatar
Re: Wheel Spacer Install?
Hello, I've seen it done at a shop and what I noticed is that the difficult part is not putting the new studs on, but getting the old ones off... just be careful and let us know how it turned out... good luck!!
~Rie
~i'm just a girl~
Old Jun 6, 2004 | 02:28 AM
khsonic03's Avatar
When you saw it done at the shop, what did they do to remove them? That is part of my question as well.
Old Jun 6, 2004 | 11:17 PM
khsonic03's Avatar
anyone?
Old Jun 7, 2004 | 09:35 AM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
You don't have to install the 5mm longer H&R studs when you install their +5mm spacer. According to the wheel shop that installed mine, as long as you have at least 4 to 4.5 complete turns on the lug nuts...here is the link:
https://g35driver.com/forums/showfla...&sb=5&part=all
Old Jun 7, 2004 | 11:25 AM
zimbo's Avatar
You'll definitely want longer studs if you're adding a spacer. I purchased the Nismo 50mm studs from Performance Nissan and they worked just fine.
Getting them out took a long time--but it wasn't technically challenging. If you have the time there's no sense paying someone else to do it.
The "hardest" part is figuring out that you need to turn the hub a bit to be able to remove each of the existing bolts. Since the emergency brake mechanism is behind the hub, there are only certain spots where there is enough room to get the old bolt out and the new one in. I found that it was easiest to turn the hub if I set the rotor on and turned the rotor. Hope that makes sense.
Also, to remove each bolt, I sprayed it with WD40, let it sit for a few minutes and then screwed an old lug nut onto the bolt and hit the lug nut with a hammer.
--Steve
Old Jun 7, 2004 | 11:53 AM
GoSooners's Avatar
I've done this several times...
1) Remove wheel and brake calipers (If you're careful, you may not have to remove the brake pads)
2) Pull the rotor towards you (may have to wiggle a bit)
3) You will now see your hub with the studs on it. Look behind it for a clearance spot - this is where you will rotate each stud to to hammer it out. For the front it is at about 10 or 11 o clock. I've only done it once on my rears so I can't remember.
Installing new ones...
1) Pull the stud through from the back of the hub and pull it in as much as possible.
2) Find about a half inch metal spacer or 3 or 4 thick washers and put it around the stud.
3) Put a lugnut through and tighten. I used an air gun when doing this to make sure it was tight. It didn't have a torque setting or anything...a torque wrench will do also. When doing this, I recommend using a lugnut you wanna toss out because as you tighten, you'll wear out the "acorn" part of it.
That's it. Put evertything back the way you took it apart.
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Jun 7, 2004 | 12:32 PM
khsonic03's Avatar
Aha, that's what I was looking for. Thanks alot How long did it take?
Old Jun 8, 2004 | 09:50 AM
GoSooners's Avatar
My first time, it took me about 45 minutes to figure everything out on one side. Once I did one side, it only took me about 20 minutes for the other side (not including time to jack up car and take off wheels)
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
Old Jun 13, 2004 | 08:30 PM
khsonic03's Avatar
Hey guys. Just wanted to let you all know that it is very easy to change out your studs. I didn't want to hammer them out because I just didn't feel that would be good for the bearings, so I used a standard puller from Sears. It worked wonders, and I didn't have to lube them with WD40 or anything. Each one came out in seconds, literally. I hightly recommend doing it this way, vs. hammering them out.
Old Jun 14, 2004 | 11:35 AM
macsak's Avatar
what's a "standard puller from sears" ?
mahalo (thanks) in advance
aloha
steve
Old Jun 15, 2004 | 06:39 AM
khsonic03's Avatar
http://www.sears.com/sr/javasr/produ...id=00946903000
The large one
jsimonk
Dec 22, 2023 03:49 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
