OEM 19" Rays... Tire size suggestions
Old Oct 19, 2012 | 04:03 PM
  #46
LoSt180's Avatar
The 19" wheels aren't the same size, so what would be the benefit of using the same tire size all around? It's not like you can rotate them. Well, I guess you could, but then you're paying to have them remounted and balanced and I'm sure that would negate any cost savings.
For example, if rotating allows you to get 3 years out of the tires instead of 2. Then assuming rotating twice a year (avg 15K miles/year & rotating every 7,500 miles), and the cost for remount & balancing is $100, then you will have spent $500 - $600 to get that extra year. After a few years, there really isn't any cost savings vs running the OEM staggered sizes.
Old Oct 19, 2012 | 06:56 PM
  #47
lcysimon's Avatar
If you are about ride quality, go 245/40/19 and 255/40/19.
There was a difference in ride quality for me with the 245/35/19.
However, the 245/40/19 took away the staggered look (assuming oem springs).
I believe the question would be the type of tires you want to get...
For me, the G is a 60 miles daily commuter and I don't drive it hard enough.
I am getting 36-38k on my front tires and 27k on the rear tires for Hankook V12.
I wonder how Hankook V12, Falker 452 and Yokaham S drive compares in terms of ride quality and being quiet.
Old Oct 19, 2012 | 07:12 PM
  #48
Big Booty Trudy's Avatar
So running 35s gives you a harsher ride?
Old Oct 19, 2012 | 07:42 PM
  #49
gowner's Avatar
Rotating tires $40 for all 4 wheels since Discount Tires does not charge for balance. I have lifetime alignment from Firestone so all I would pay is the $40. I believe paying $80 a year is not bad as each tire is $300 including warranty. So if I can save a bit on these tires means I could eventually with the save buy a set of tires for my 20s currently running 255/30/20 and 285/30/20. Also, in the future I can always buy a set for the rear most likely 255/35/19 or 255/40/19. Thank you once again to all who have commented; this is why I love this site!
Old Oct 19, 2012 | 09:58 PM
  #50
herrschaft's Avatar
Yes, smaller sidewall equals less "cushion"
Old Oct 19, 2012 | 10:09 PM
  #51
herrschaft's Avatar
It can be done and can benefit those who go through tires in less then a year. A .5" diference doesn't mean squat. When I had a square setup I occassionally swapped the rears and fronts to equalize tire wear, didn't need to rotate.
Old Oct 22, 2012 | 09:52 AM
  #52
Wontonschicken's Avatar
Are there any X's out there that are running different side wall sizes?
Old Oct 23, 2012 | 11:26 AM
  #53
Anyone??
Old Oct 24, 2012 | 07:35 AM
  #54
sprix's Avatar
For most service shops (especially if your car has unidirectional tires) that actually is a rotation. Front to rear swap is what they mainly do.
Old Oct 24, 2012 | 10:09 AM
  #55
Swivel's Avatar
Moderator
Originally Posted by JaE35
i'd reccomend to anyone 245 35 in the front and 255 35 if i were to do it again
Completely agree, that's been my setup for a couple of years now.
CAUTION: pic-whoring ahead!
Old Oct 24, 2012 | 10:34 AM
  #56
How's the ride quality with 35s? ^
Old Oct 24, 2012 | 10:40 AM
  #57
Swivel's Avatar
Moderator
It's pretty good, I think I've mentioned before that my car is a DD and family car, so no undue harshness.
Old Oct 24, 2012 | 09:18 PM
  #58
gowner's Avatar
I just ordered the Michelin Pilot Sport A/S 245/35/19 all around. It was a hard decision but one I needed to make already. I would like to thank all of you for your suggestions and wish all the best. I will post pictures once I install them. Take care!
Old Oct 24, 2012 | 10:14 PM
  #59
Good choice and good luck man! Let us know.
Old Oct 26, 2012 | 06:12 PM
  #60
AdrianVQ's Avatar
225/35R19 in the front, 245/35R19 in the rear
Im into the stanced look lol. That will give a subtle stretch but not too much. Would look very nice.
