Shaving wheel hub
Old Jan 3, 2009 | 03:01 PM
pdjafari's Avatar
Shaving wheel hub
Hey guys,
I was looking to get a set of my friends wheels he's running on his M5. Prob. is that the offsets on the M5 are around +20 and mine run no more than +25 w/o rubbing. I was looking to find a shop that could shave about 3-5mm off the hub of the rims to get them to fit w/o bulging from the fenders or rubbing real bad on the fenders. I will roll the rear fenders, but unfort. the 335s front fenders are plastic so no rolling the front (they should fit anyways).
Any ideas of a good reputable shop that will perform this type of machine work?? Most likely done with a lathe or similar type of machine...
Old Jan 3, 2009 | 04:06 PM
nghiars's Avatar
if you were to shave off 5mm, wouldnt that lower the offset from +20 to +15?
Old Jan 3, 2009 | 08:04 PM
Buzz Killington's Avatar
From: Intergalactic proton powered electrical tentacled advertising droids!!!
Not quite, it'd move the mounting point from it's present point to 5mm inwards ( due to the machining ) which would essentially raise the offset of the rim to 25
I don't believe it's safe to machine that much off the rim though...
Old Jan 3, 2009 | 08:16 PM
Sbeck's Avatar
run some camber or get smaller tires
Old Jan 6, 2009 | 05:49 PM
kenchan's Avatar
i would run more camber and stretch the tires more (use narrower tires than
wat it comes with) to achieve the clearance.
im not sure how the structural rigidity is affected when you shave off the
disc...so i would try to stay away from that unless your car is more like a
a showcar (static model).
Old Jan 6, 2009 | 06:02 PM
HenryLee's Avatar
Do it right, neg camber and some stretch tires! FTW
Old Jan 6, 2009 | 06:03 PM
express705's Avatar
OT-
OP, you stole my avatar and youre using it on e90post.com
COOL! lol
Cajuncowboy
Jun 21, 2021 09:47 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
teamghost
Jul 28, 2015 04:52 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
