Repairable?
Old Jan 19, 2009 | 06:47 PM
Drtybrd61's Avatar
Repairable?
my g/f needed new rims and a found these stock Si rims for her civic. 3 of the rims are flawless one is messed up in the back.
1. can it be repaired?
2. does it need to be repaired? can she drive on in?
thanks!
Old Jan 19, 2009 | 07:00 PM
JOKER's Avatar
CLUB MODERATOR
do you know what happened?
Old Jan 19, 2009 | 07:01 PM
Drtybrd61's Avatar
the guy said he didn't tighten the lug tight enough and the rim cam loose while driving.
Old Jan 19, 2009 | 07:04 PM
wreckeds2k's Avatar
looks like someone tried to make coupe wheels fit under a sedan.. The stud holes arent reamed out. looks like someone has been hacking on the backside.
Old Jan 19, 2009 | 07:06 PM
JOKER's Avatar
CLUB MODERATOR
anything is repairable but it seems that it would cost allot of money to repair it.
You could take it to a repair shop and see if they can put in on a balancing machine and see it it vibrates at all.
cuz most of the damage is close to the center it might not vibrate much or not vibrate at all.
if there are any cracks in the damaged area then this wheel has a potential of falling apart at high speeds.
I'm not sure what would be a procedure to repair such wheel. If any of the material is missing then it would need to be welded on. So once again the center of the rim will get overheated and once again might develop major cracks at high speed. If repair shop will simply grind the damaged area out that will also be a concern cuz now it will be thinner and weaker
So you really gotta check with repair shop to see if it has any potential of being restored.
I highly doubt it and I think that most of the shops might simply refuse to do it do to the liability.
Old Jan 19, 2009 | 08:30 PM
Drtybrd61's Avatar
just got back from the tire shop. you were right Joker. They said it couldn't be repaired and even if they tired, they wouldn't recommend driving on it.
you guys are all great. thanks for the fast responses.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
lavtxa
Sep 21, 2015 11:51 AM
toadfire
Sep 21, 2015 07:15 AM
