Stock 17's to Rays 19's...but Tires?
Old Jan 23, 2009 | 12:44 AM
The Stimulation's Avatar
I currently have the OEM 17's that came with the '06 sedan (non-sport) and I am considering going with the 19" Ray's Engineering coupe wheels. My issue is tire size. I don't want something that a narrow selection where tires are costing $300 per tire, but I do need something close to stock size.
What recommendations would you suggest? I will use the same size tires all around. Also, just wondering if it's better to go with something with an overall diameter a little smaller than a little larger than original or vice versa?
Old Jan 23, 2009 | 12:47 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
245/40/19 if you want a bigger sidewall.
245/35/19 if you want it to look a little better and a cheaper tire with more options.
-GP-
Old Jan 23, 2009 | 02:07 AM
Skaterbasist's Avatar
Retired SuperMod
Most of the tires for the Coupe 19's (max performance) are going to be expensive. I also suggest going OEM sizes.
Old Jan 23, 2009 | 10:30 AM
Yeah I'm beginning to notice that. Cheapest I've found are 170 per tire. That same exact tire I got for $108 for a 20" rim. The Rays don't come in 18's do they?
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
realtalk21
Jul 20, 2015 09:07 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
