Good stretch for 19x9&10 & rear rubbing issues
Old Jan 25, 2009 | 08:57 AM
jdm-v35's Avatar
I am looking to change my tires and am wondering what tires would be a best fit to stretch on my wheels. I seem to be having a problem with the rear tire rubbing on the tab on the rear fender that holds on the rear bumper on. It only rubs when I go over a big bump or dip.
specs are:
AME circlar SpecR
19x9, 19x10 +15 offset all around
Jic FLT-A2 lowered to tuck 1 inch of tire in front and rear.
front and rear ichiba camber kit. front to stock spec, rear -2 degrees camber, 0 toe.
rear fenders rolled flat.
current tires: 245/40 front, 275/35 rear.
anyone else having this problem with rubbing in the same area?
Old Jan 25, 2009 | 01:03 PM
HXS's Avatar
HXS
235/35 front and 265/35 rear?
Old Jan 26, 2009 | 01:37 AM
jdm-v35's Avatar
I am not sure if that will be enough. I tried doing some adjustments today again, I hope it works. If not I think I will need t stretch. I was thinking more like.. 225/35 front, 255/30 rear. don't know how safe that would be though so looking for any opinions for a reasonably safe setup
Old Jan 26, 2009 | 01:42 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
a 255/30 on the rear would be ridiculously small and most likely start messing with your VDC.
I'd go with a 225/40 up front and a 255/40 in the rear.
-GP-
Old Jan 26, 2009 | 10:21 AM
Triple8Sol's Avatar
What kind of tires are you running? Have you tried trimming down that tab?
Old Jan 26, 2009 | 10:35 AM
Og_Dave's Avatar
alot of people run 245/30's up front and 265/30's in rears , i know a few people on here run that setup i believe , could be wrong though
Old Jan 26, 2009 | 05:20 PM
jdm-v35's Avatar
current setup is in my first post. tires are 245/40 front, 275/35 rear. maybe I should just raise the rear 1/2 inch lol
Old Jan 26, 2009 | 11:52 PM
not on a G... those are horribly small for 19's. In 20's, those sizes would be fine.
-GP-
Old Jan 27, 2009 | 04:32 AM
Triple8Sol's Avatar
Let me try again. What kind of tires, as in brand/model
Old Jan 28, 2009 | 10:19 AM
Corrosive's Avatar
Not sure of what brand... but I have some 225/40 on my 9.5 wide rims... its a hell of a stretch and I feel every bump but it fits... Hope that helps a tad
Old Jan 28, 2009 | 11:40 AM
Triple8Sol's Avatar
If you're too lazy to go and look at your tire, then I guess I can't help you. Best of luck.
Old Jan 28, 2009 | 04:18 PM
jdm-v35's Avatar
that is not me. my tire brands are potenza re50 rear michelin pilot 2 fronts.
Jusseth
Sep 13, 2020 12:25 PM
rezendvous420
May 31, 2020 01:26 PM
hdmark
Apr 29, 2019 04:31 PM
Popes
Jul 29, 2015 05:07 PM
