Mandatory spacers on iForged rims?
Old Jun 15, 2004 | 03:50 PM
rob575's Avatar
Just spoke with Vince, he said for 03 & 04 the Brembos are a litte bigger in the back, therefore he'll be including a 3mm spacer with my 19" Aeros. Everyone else getting the same spacer? Is there anything I need to be concerned about regarding this spacer?
Old Jun 15, 2004 | 05:48 PM
protocav's Avatar
Re: Mandatory spacers on iForged rims?
i have an 04 and i am not running any spacers with my iforged. i will be adding a 3mm for the front, however, for peace of mind.
Old Jun 16, 2004 | 01:53 AM
bkchang79's Avatar
proto, if they're aren't touching your brembos, why do you need the spacer? I don't have a problem with my iforged wheels.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
Old Jun 16, 2004 | 02:13 AM
waijai's Avatar
i.love.gold
MIne came w/ spacers, but I don't think I need them.
Ivory Pearl coupe
Old Jun 16, 2004 | 10:46 AM
Black2003G's Avatar
Yes i ran into this problem also. I wasn't happy about the the spacer, but then again its only 3mm.
Also, is anybody getting a rubbing in the back. I am running 18x10 with 4in lip and 275/40/18 tires. I am having my fenders rolled tomorrow to fix this problem
Old Jun 16, 2004 | 12:03 PM
tgalvez's Avatar
Guys.
MAKE SURE YOU USE THE SPACER!!!.
I did not at first, and my rear brembos got scratched!!
Old Jun 16, 2004 | 12:11 PM
petrog35's Avatar
So you only need the spacers if you have brembos?
5AT/DG/Premium/4pc.Aero
Injen CAI
Aluminum Pedals
18" Factory Chrome Wheels
Old Jun 16, 2004 | 12:35 PM
protocav's Avatar
the wheels arent touching my brembo's but the clearance is so tight that i am afraid of rubbing during extreme driving (most rims will bent slightly, more so if they are larger diameter). i have a scratch on my front caliper, and i'm not sure if the wheel grazed it, or if some road debris got cought in there. i am just doing it for safety and for a slightly more aggresive look. it was pretty painful to see the mark on the brembo's, and i don't want it to happen again.
Old Jun 16, 2004 | 01:09 PM
R2 V35's Avatar
You shouldn't need the spacers. Unless you didnt tell Iforged that you have Brembo's....
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Is simplicity best or simply the easiest"
Old Jun 16, 2004 | 02:30 PM
rob575's Avatar
thanks for the replies. I definitely told them about the brakes when I ordered and was just surprised when I was told it would require a spacer. I would have thought since they are custom-built wheels there would have been some way to avoid using the spacer. I guess if others are using it, I shouldn't be worried.
seagrasser
May 3, 2022 09:43 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
