Sedan wheel/tire question
Old Jun 16, 2004 | 11:20 PM
Bluestreak's Avatar
Hi all,
My wife just leased an '04 6m/t sedan with premium and aero (I have my own '03 6m/t coupe). Got a great deal- our only complaint is that it came with Bridgestone Turanzas- which are rated horribly and do nothing to enhance the experience. I'm looking at a wheel/tire package with Mille HT3, 17X7, and BF Goodrich Traction T/A V's (read great things about them for sport all season use). As most of you know, the stock tires are 215-55-17, and the BF Goodrich only come 215-50-17. I looked at the thread on wheels/tires, but that deals mostly with adding much bigger wheels. Anyway, if anyone has made this kind of change, can you let me know:
- does this size fit OK?
- does it mess up the VDC at all?
- does it mess up ABS at all?
- Can the tire pressure monitor be transferred (is it difficult)?
- If you don't transfer the tire pressure monitor, does it reflect on the dashboard warning light?
- anything else you can share that I should know before doing this?
Thanks to anyone who can share their experience
Old Jun 17, 2004 | 08:42 AM
socalg35's Avatar
Re: Sedan wheel/tire question
The only thing I can add to this post is re tire size. If you go to miata.net, then the garage section,
look for the tire size calculator...you can play with all sorts of sizes.
F.Y.A.
Old Jun 17, 2004 | 08:47 AM
ekaz's Avatar
The 215-50-17 are over 3% smaller than the stock tires therefore it is both unreocmmended and may adversly (sp?) affect the VDC and ABS. Not sure on the tire pressure monitoring system, I think there is a thread somewhere regarding that. I know tirerack has a pretty nice aftermarket system. As for the warning light, it will not be on constantly. If you'd like, you can click on the link in my signature and then on the links there which will take you to a tire calculator, you want to stay within 3% of stock tire size.
Diamond Graphite/Graphite/Prem. pkg./Navi.
ASG 7-wire grounding system
Tint
Z-tube
K&N drop-in
Volk GT-C
Eibach Springs
http://ekaz76.home.comcast.net/myg35x.htm
Old Jun 17, 2004 | 10:07 AM
cato's Avatar
SouthernComfort Moderator
I put the Kumho 235/50/r17 tires on to replace those POS EL42s and have been very happy with them.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old Jun 17, 2004 | 11:45 AM
3point5SE_Auto's Avatar
215/50/17 does not have the same load rating as stock. You should never lower your load or speed rating. I recommend increasing or keeping it the same.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old Jun 17, 2004 | 11:51 AM
Q45tech's Avatar
The important thing for safety and longevity is to make sure what ever tire you chose at least meets the oem load index rating.
Installing a lower strength tire [below factory specs] can be used against you in court as significant negligence on your part.
Going higher in reserve rating is even better.
The EL42 have soft flexy sidewalls to enhance ride, just go with the Michelin Sports if she can stand the extra maintenance of a directional tire..
Old Jun 17, 2004 | 04:06 PM
codeflux's Avatar
i've been riding on Michelin Pilot Sport A/S 235/50-17 and very happy with them.
________________________________________
2003.5 4DR AT Sport - Brilliant Silver w/Black Interior
http://codeflux.com/iv/g35/
Old Jun 17, 2004 | 04:58 PM
doogie's Avatar
I'm just glad to hear from someone who hates the Turanzas as much as I do. They're a friggin' death trap in the rain. I'm interested in this thread because I'm looking to get rid of mine too.
Jase aka Doogie
04 G35S
Old Jun 17, 2004 | 10:22 PM
chinee's Avatar
Don't get the Falken Ziexs... damn noisy tire... they stick pretty well and have an agressive look... but the damn noise....
<font color=red>chinee</font color=red>
03.5 G35s
Old Jun 17, 2004 | 11:55 PM
johnzg35's Avatar
I recently installed Ziex 512s (225/55R17) on my sedan and I don't find them to be noisy whatsoever. They're similar to the Bridgestones if not quieter. But this is all subjective anyway. I however do agree with you on how they grip and look. It's a very nice looking tire.
Old Jun 18, 2004 | 02:13 PM
Marty's Avatar
I changed from Goodyear RSAs (even worse than EL42s) to Goodyear Pilot Sport A/Ss (235/50/17) when I got the car home from the dealer. Tremendous improvement in all phases of handling and braking!
Old Jun 18, 2004 | 07:51 PM
Bluestreak's Avatar
Hi everyone,
Thanks for the quick responses- and the lessons on alternative tire sizes. As I'm sure you all know, there aren't many choices for high performance all season tires in a compatible size. After an exhaustive search through the Tire Rack website, and checking out the comparitive ratings, I think we'll do what some of you have done- go with the Michelin Pilot A/S in the 235/50/17. Think we'll get them mounted on a set of Mille rims my wife likes. We'll give up the tire pressure monitors, but I'd rather not get into removing tires from their rims, especially on a lease car. These Michelins have gotten pretty good grades for snow traction as well, which was also one of our primary concerns.
Thanks again!
Old Jun 19, 2004 | 09:27 AM
chinee's Avatar
johnzg35,
That's the same model and size that I recently installed, and at the beginning I didn't notice the noise, but it's really prevalent at speeds below 15mph. I first noticed it while making a wide 180 degree turn in a parking lot and the radio off. I had recently gotten my rotors resurfaced at the dealer so initially though it was the brakes...now after 1000 miles, I think it's the tires. Straight line noise isn't an issue, it's at slower speeds, especially when turning.
03.5 G35s
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
mushu
Jul 15, 2015 03:55 PM
