mix match front and rear tires?
Old Feb 5, 2009 | 05:06 PM
phatice's Avatar
I was a doing a little searching and people were saying good and bad things about it. Well i found a pair of used rear tires for $95 each (Pirelli P-zero 275/30/20) and I was wondering if it's ok to use them with Nitto NT555 245/35/20 for my front tires?
Old Feb 5, 2009 | 05:41 PM
SenorCole86's Avatar
I don't see a problem with it. Be prepared for some understeer problems (at least more than usual) as I imagine the Pzeros are stickier than the Nittos.
Old Feb 6, 2009 | 10:34 AM
phatice's Avatar
is that the only problem that i should be worried about? understeer?
Old Feb 6, 2009 | 02:30 PM
As long as you don't put different tires on either side of your vehicle (i.e. different tires on the left than the right), I don't foresee any other problems unless there is some strange phenomenon with the VDC system I'm not aware of. Maybe someone will chime in on that regard.
The two tire types will not wear the same, so this is obviously only a temporary fix until you can get tires which are the same all around. If the two tire types have significantly different mass moments of inertia, you might have some strange brake wear. Seeing as how they are both radial tires though, I don't think you will have a problem.
Old Feb 6, 2009 | 04:13 PM
Triple8Sol's Avatar
The problem is that those are the WRONG SIZE. Get the right sizes, and you'll be find running different tires.
Old Feb 6, 2009 | 06:31 PM
phatice's Avatar
i thought 245/35/20 front and 275/30/20 rear is a fairly common setup? am i wrong?
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
