what size tires to get for 19' oem on sedan
Old Feb 12, 2009 | 11:59 PM
CandlestickPark's Avatar
ill Sedan
As others have said I'm running 245/40s (Falken FK452s) all around. I rub a bit in the front on very steep inclines (very rarely happens). My fenders are not rolled and I don't rub in the rears (don't have a camber kit, if I dialed my camber in I would rub for sure). I've gone on a road trip with a trunk full of luggage and still didn't rub, was very close though. Will be going lower soon and installing a rear camber kit, definitely will need to roll my fenders.
Next set will probably be 245/35 and 255/35 because I won't be worried about filling the wheel gap anymore once I'm lower. But I'll have to find another tire to go with because Falkens don't come in 255/35.
Old Feb 13, 2009 | 12:01 AM
Wannabe6MT's Avatar
-MN G Crew-
I think that looks good.
Marcus, found a better deal on tires. Im getting them at cost from my sisters bfs work. $148.50 a tire!
Old Feb 13, 2009 | 12:09 AM
ill Sedan
That's awesome Yanik...hook me up!
Old Feb 13, 2009 | 12:14 AM
Wannabe6MT's Avatar
-MN G Crew-
lol i would if i could. Family discount :O
Old Feb 13, 2009 | 12:29 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
Kumho Ecsta SPT --(F)245/35/19 -- (R)255/35/19
This size and brand has worked great for me. It has a good ride quality, especially when you consider 19" size and 35 series. Naturally my spring-setup helps b/c it is the same spring rate as my stock sport springs mated to sport shocks/struts. Size options are good along with prices. No wear issues b/c I have no extreme negative camber--more neg. camber than stock, but less than a coupe. No camber kit, but my suspension guru did a slight mod to the rear stock camber arms. I'm rolled in the rear as a precaution b/c I did not want to rub in any circumstance. I never have rubbed and I don't need crazy tire-killing camber to accomplish this.
Attached Thumbnails what size tires to get for 19' oem on sedan-img_2490_1_7_1.jpg   what size tires to get for 19' oem on sedan-img_2781_1_1.jpg   what size tires to get for 19' oem on sedan-img_2748_1_1.jpg   what size tires to get for 19' oem on sedan-img_2772_1_1.jpg   what size tires to get for 19' oem on sedan-img_2782_1_1.jpg
Old Feb 13, 2009 | 12:38 AM
Texan1's Avatar
looking forward to your new pics, it's gonna look awesome--something your car always accomplishes
Old Feb 13, 2009 | 12:51 AM
Wannabe6MT's Avatar
-MN G Crew-
Tex, your car is so unbelievably clean. i love it
Old Feb 13, 2009 | 01:17 AM
Texan1's Avatar
Thx, I washed it today and got 2 compliments on the car from passers by. If you mean clean as in style thx on that too.
Old Feb 13, 2009 | 07:14 AM
Texasscout's Avatar
I run the Privats now. The M45's need some attention, one is bent and the rest need to be powdercoated.
Old Feb 13, 2009 | 11:26 AM
ill Sedan
Thanks man. It'll be a while before I change sizes, just got new tires about 6 weeks ago.
Old Feb 13, 2009 | 11:55 AM
keen1801's Avatar
I'm running 245/40/19 on A34 Nismo wheels. I went with the Falken fk-452 and I would highly recommend them. They look great and have been really good in the dry and wet. They are not noisy at high speeds and the ride is great.
Also I'm dropped on revised Z springs/shocks up front and coupe springs/z revised shocks out back and I think it looks good. Wheels are 19x8.5 with +35 mm offset and they are almost flush, if not flush, with the fender. I have no rubbing issues with the tires on driveways. I did roll the rear fenders slightly but not much.
Old Feb 13, 2009 | 01:16 PM
blklude98's Avatar
I believe Jeff92SE and I both run the same sizes. STOCK 19" tire size up front (225/40/19) and 255/35/19 with ZERO rubbing issues both on the Z/G coupe spring combo.
Old Feb 13, 2009 | 02:08 PM
ttrank's Avatar
Grocery getter
I would trade the little bit of ride and off speedo for the much better looks of 245/35's.
Old Feb 14, 2009 | 01:20 AM
Texan1's Avatar
b/c you misled by your vague post, you should fly to Houston and offer G photo shoots at 50.1% discount.
Old Feb 14, 2009 | 01:22 AM
  #30
Texan1's Avatar
no such thing as revised front 350 Z springs.
