tire pressure. how much?
Old Feb 13, 2009 | 02:30 AM
4drmadness's Avatar
haha, lol. na man. i really need to make some vids. my setup is stillen gen 2, kinetix hfc, and dc headers. oh n popcharger, z tube also help me being super loud, lol. ill take some this weekend.
you have the 2nd gen stillen now?
speaking of which, i just got pulled over on monday for my exhaust haha
the cop let me go, tho. maybe it was my 11-99 license plate frame
any new sound clips?[/QUOTE]
Old Feb 13, 2009 | 02:32 AM
cremaster's Avatar
dood, that sounds like it'll be way too loud for my tastes haha
you should get a decibal meter and see what you're read out is
Old Feb 13, 2009 | 02:33 AM
4drmadness's Avatar
hahhaha, i shud. i really like it tho. its sounds really good, and the gains are amazing. Im finally getting a tune this tuesday. im super excited. going to HBSPEED
Old Feb 13, 2009 | 02:37 AM
infinus's Avatar
You can pretty much get away with murder with one of those haha.
Old Feb 13, 2009 | 02:38 AM
jutn35's Avatar
G35 Coupe
Owners Manual.......its in your car, but 30 is a good number.
Old Feb 13, 2009 | 02:41 AM
infinus's Avatar
Its also listed on the drivers side door for those with no manuals or too lazy to look it up
Old Feb 13, 2009 | 11:55 AM
TurTLe*'s Avatar
just so we are clear.. you had 30psi when the tires were cold?
when your tires are warm it could be like +2-5 PSI, i recommend checking tire pressures in the morning. before the car is driven to get a more accurate number. I had a tire light come on while i was driving when i got home all where 30psi. i figured when it was cold it most likely dropped below the min spec of like 26-28 or something. pumped it up to 35psi and in the morning i checked it all where at 32 and stable.
Old Feb 13, 2009 | 11:58 AM
cremaster's Avatar
so far it's been my best mod yet
Old Feb 13, 2009 | 02:09 PM
ttrank's Avatar
Grocery getter
I run ~35-38 most of the time.
Old Feb 14, 2009 | 10:13 AM
Mustang5L5's Avatar
you're supposed to add X amt of pressure for every inch in diameter you go up. so, for 17s 32 to 34 should be good.
for my 235 35 19 and 265 30 19, 36 to 37 was recommended by a reputable tire shop.
Not always the case. It really depends on the tires contact patch area vs actual wheel diameter. It also depends on the manufacturer and how stiff the tire actually is. There really is no blanket tire pressure that works.
If you have a set weight, and put a wider tire on, the weight is spread out more so in theory you need less pressure to sustain that weight. It's like if you do pushups on your fingertips vs on your fists. You weight the same, but obviously there is more pressure on your tips vs fists, so you need more pressure to hold you up.
WHat I do is chalk or paint the tire. I stencil out a band across the tire with paint and spray it and let it dry. Then i go drive. Every couple of mile i pull over and notice where the wear is coming from. If it's more in the center than the edges, i let air out. If it's more on the edges, i add some air. You can usually dial it in pretty good this way. It takes a little work, the end result is nice even tire wear over the life of the tire. I've gone down to the wear bars with my tires looking perfectly flat across like this.
On my other car that came stock with 225/60/15's, the stock tire pressyre was 35PSI. WHen i put 275/40/17's on, 28PSI would do the same job. That's 7PSI less on a wheel 2" larger in diameter but with a contact patch 50MM wider.
My point is every car/tire/wheel combo will be different
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
