will i have to fender roll with this setup?
Old Feb 23, 2009 | 11:36 PM
badnblk's Avatar
ive got an 04 coupe doin a fullsuspension setup that consists of megan coilovers spc camber kits f/r, sway bars, chassis bars the works and my rims and tires are exe konvex 20x9 +20 245/30/20 and 20x10 +25 275/30/20 im lookin to drop the car so that the fenders will sit right around the tire maybe lower i dunno yet. should i roll the fenders for this and is it front and back i gotta roll or jus the back?
Old Feb 25, 2009 | 09:12 PM
solobaric's Avatar
Your wheel/tire application will not rub even with OEM alignment. You should be safe.
The rear clearance may be somewhat close without a fender roll(about 6-8mm) between the top of the tire and the fender but will not pose a problem unless you plan to use snow chains.
Old Feb 25, 2009 | 10:01 PM
Thinkdiesel's Avatar
dont really need a roll with those offsets and factory camber specs.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
