Wheel Question
I'm thinking about purchasing a set of Work Meister S1 and am in need of some information before I purchase them.
Front: 19x9.0 +25
Rear: 19x10.0 +15
I really want these because they are selling for a great price, but commonly the fronts are 19x9.5 to clear the brembos brake calipers (per G35driver search function). What size spacers will I need to purchase to have this clear the brembos? Any help would be appreciated.
Front: 19x9.0 +25
Rear: 19x10.0 +15
After careful research and measurements, I was able to fit these bad boys on with 15mm spacers with extended studs. Spacers with built in studs will not work due to the cleareance issue with the oem studs. Due to the Work wheels not having a concave groove adjacent to the stud hole, this would have been the issue. The oem studs stuck out beyond the spacer causing the wheel to not be flush. So, basically 15mm spacers with extended studs were the way to go and they look very aggresive. This is just a heads up to whom ever runs to this similar situation that I faced in my pursuit to go with rare wheels.
kinetek
Aug 3, 2015 04:25 PM
