non-staggered rims with staggered tires on g35 coupe?
Old Mar 22, 2009 | 10:40 PM
G35-M6's Avatar
saw a set of 18x9 +30 rims. looks like it should fit and clear bbk.
however, can i run a set of non-staggered rims on a g35 coupe?
i will plan to run staggered tires tho..
225/45/18 (F) and 245/45/18 (R)
thanks you.
tried searching, no results, hope the thread helps those who doesn't know either
Old Mar 23, 2009 | 12:27 AM
redlude97's Avatar
you can run staggered tires on correctly sized nonstaggered wheels, but I wouldn't recommend it in this case. 225 is too narrow for a 9" wheel IMO
Old Mar 23, 2009 | 12:29 AM
Calvin's Avatar
Overglorified Altima
Yes, the OEM 18" wheels for the coupe are non-staggered, but the tires are. Also agree that 225 is too small for a 9" wheel.
Old Mar 23, 2009 | 01:07 AM
GLuXuRy's Avatar
run the 265 =P
Old Mar 23, 2009 | 01:25 AM
G35-M6's Avatar
so i should run something like 235 (F) and 265 (R)?
so 225 & 245 should just be for 8 or 8.5?
Old Mar 23, 2009 | 03:08 AM
G35-M6's Avatar
alrighty..
i don't want to start another thread just to ask will these fit and clear bbk yet, hopefully people can also answer me these questions here.
so i know its not the offset that clears the brembo bbk, but the style of the rims. so these are the styles i'm looking into. can you guys let me know if it would fit based on the style, offset, size, etc.
thanks
(1) TSW Laguna (18x9, +20 all around)
http://www.discounttiredirect.com/pr...lag.hsm.xl.jpg
(2) Enkei PKR (18x8.5, +24 all around)
http://www.discounttiredirect.com/pr...kpkr.bm.xl.jpg
(3) Konig Runaway **Two options** (18x8, +35 *OR* 18x9, +30)
http://www.discounttiredirect.com/pr...nrun.sb.xl.jpg
Discount tire direct has those rims for $610 a set with free delivery.
Old Mar 24, 2009 | 03:34 PM
scotts04MT6's Avatar
245-255 front, 265-275 rear on 18x9 +30 wheels.
BTW, the +30 will be very close to the front Brembo. You may need a 2mm shim-spacer depending on the concavity of the wheel. You may choose to run a spacer in the rear to push the wheels out some as well - your choice but not necessary for rear Brembo fitment.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
BlackGee35
Jul 23, 2015 01:36 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
vstypicals
Jul 20, 2015 10:55 PM
