noob question. will these fit?
Old Apr 2, 2009 | 02:27 PM
verilath's Avatar
sorry I dont know much about fitment and sizes and I just wanted to know if these 19" Axis Pentas would fit on a '07 non sport 5at STOCK coupe.
"Axis penta mesh silver finished
Front 19x8.5 offset 40 with Nitto extreme NT555 approx 70%
Rear 19x9.5 offset 45 no tires
5x114.3 lug patern
asking for only 800 bucks for them."
Old Apr 2, 2009 | 02:31 PM
O HELLA OEM's Avatar
they will fit
but the offsets arent to good for a coupe
that offset is geared for sedans
you can always run spacers though
at $800 thats a steal
GL
Old Apr 2, 2009 | 02:37 PM
verilath's Avatar
yeah i was caught by the price. so just to educate a noob like myself, is 5x114.3 our g35 coupe bolt pattern? and what would be an appropriate offset to run?
Old Apr 2, 2009 | 02:38 PM
EL-EE-ES's Avatar
yeah your going to need at least 20mm spacers all around
Old Apr 2, 2009 | 02:40 PM
ShanesG's Avatar
^Yes, a decent offset would be to cut those by about 20-30mm, and thats still conservative
Old Apr 2, 2009 | 05:11 PM
EL-EE-ES's Avatar
offsets run from the mid 20s or lower for coupes. the lower you go the more agressive they look. $800 bucks is a steal, then look to spend a few more to get spacers. to get a agressive look, look at getting 30mm rear and 25 front. look in the "check out my wheels" section on here to get ideas of offsets
Old Apr 2, 2009 | 06:49 PM
az1anbeethoven's Avatar
even though they are aights in pricing, i would not get them...run the right offsets and maximize your lip size
Old Apr 2, 2009 | 07:18 PM
nghiars's Avatar
offsets are way too weak for a coupe.. heck i think they're too weak for a sedan.
Old Apr 2, 2009 | 09:22 PM
verilath's Avatar
hmmm, interresting point. So what is the difference between having a low offset and getting spacers? won't they give me the same look in the end, or is it different?
Old Apr 2, 2009 | 09:50 PM
EL-EE-ES's Avatar
in away they push the whole wheel out like low offsets...but with lower offset you can get a bigger lip
Old Apr 2, 2009 | 09:59 PM
erklep's Avatar
the higher offset will make your wheels look sunken in. i have that same setup but recently installed 25mm spacers all around. it pushed the wheels out 1 inch to sit flush with the fenders. i came across a super deal like you and said "what the hell, why not?"
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
