BBS Evolution-II or BBS FM (Magnesium)
Old Jul 4, 2004 | 07:42 PM
neffster's Avatar
Does anyone know where I can buy either of these wheels? I've seen them before on RoadFly and I know they're expensive (exactly how expensive I don't know). I know they comes in sizes to fit an E46M3 (18") and was wondering if they would fit the G35C-6MT?
here's a picture of one of them but I can not find the FM on the internet anywhere (especially in English).
Can anyone offer any help? TIA...
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Old Jul 4, 2004 | 10:21 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: BBS Evolution-II or BBS FM (Magnesium)
They look like SF Winnings. I've never seen the others.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Jul 5, 2004 | 04:52 AM
Buddha's Avatar
omg, they are 1800 a wheel. so 7200 a set. Also you dont' want to use magnesium wheels because they are very soft and can bend easily. On top of that, 7200 is just extreme for a set of wheels. Check out the BBS RGR's if you like that look
04 G35C 6mt/aero kit/nav/premium
Old Jul 5, 2004 | 07:26 AM
neffster's Avatar
I just know that 16 lbs. per wheel is insainly light for an 18" forged 1 piece wheel. I figured I'd look into it.
Old Jul 5, 2004 | 02:53 PM
Cruz's Avatar
Try Speed Of Sound Performance 850-769-3465. That's where I got my RGR's.
XMLM
Old Jul 5, 2004 | 10:42 PM
Sukairain's Avatar
16lbs a wheels for forged magnesium? Are you sure about that? Volk CE27N weights 16-17lbs each and these are forged aluminum rims that cost around $600 each. The Volk 18" magnesium rims weight around 13-14lbs each, and they cost around $1200 each........ Either way the BBS weight vs value doesn't add up. I would advice more research. Besides, I am sure you can find better ways to improve performance for $7200...... You don't buy that unspring weight X 10 argument, do you?
Old Jul 6, 2004 | 06:00 AM
neffster's Avatar
No, more like x3 to x4 depending on the weight of the car. I've looked for the CE27N's and could not find them on google anywhere. Are you sure about the 19 x 9.5 size only being 14 lbs. each? That's extremely light... I checked out this website and didn't see the CE27N's.
Could you be referring to the Volk CE28N 17x7.5" weigh (6.6kg) which is 14.5 pounds. They are cast wheels and are not forged. I will not consider cast aftermarket wheels after my last horrible experience with this type of wheel. If you add 2 inches to the diameter and 2 inches to the contact patch you're probably adding 4 or 5 more pounds. That's pushing 19-20 pounds for a cast wheel. No thanks...
Also, I would not conseder spending more than ~$2000 on rims alone. The magnesium question was asked because I had no idea what they would run, and still haven't had anyone take me to a link to show me that they actually cost $1800 per wheel. I also did not know that Magnesium was soft. I thought it was just the opposite.
Still learning here... please bear with me.
Old Jul 6, 2004 | 12:04 PM
Sukairain's Avatar
No no, the CE27Ns are around 17lbs each in the size you are looking for. The 14lb wheels I refer to are the Magnesium Volks, the CE27N like you said, has cast spokes and forged lips.
Old Jul 6, 2004 | 02:56 PM
neffster's Avatar
Do you have a link to a photo?
Old Jul 6, 2004 | 04:18 PM
Sukairain's Avatar
Try this link:
http://www.forperformance.com/wheels.html
They have the whole Volk line up.
seagrasser
May 3, 2022 09:43 AM
NohoG35revup
Aug 22, 2015 12:13 PM
richboy
Jan 25, 2006 11:28 AM
not4another
Nov 20, 2003 03:44 AM
Nismoboy
Oct 21, 2003 10:31 AM
