What size spacers do I need?
Old Apr 12, 2009 | 05:49 PM
G35_sylvi's Avatar
Hey guys,
Quick question... what size spacers would i need for 18x8.5 +15 offset on a 04 G coupe? I want it to sit flush with the fenders... I was thinking about 25mm all the way around... is that too much? Can anyone recommend a brand?
TIA!
Old Apr 12, 2009 | 06:01 PM
eurodre's Avatar
how low are you? being flush depends on how low you are
Old Apr 12, 2009 | 06:07 PM
G35_sylvi's Avatar
You can fit around three fingers under my front bumper. Same with the sides...
Old Apr 12, 2009 | 06:11 PM
eurodre's Avatar
i have the oem wheels with 25mm spacers all around and im 3 3/4 off the ground and im not flush but since ur stock height then 25 should be relatively flush
Old Apr 12, 2009 | 06:44 PM
gr8huntr's Avatar
U should be able to go 25mm spacers , a real good kind are Ichiba's ....good luck
Old Apr 12, 2009 | 06:45 PM
G35_sylvi's Avatar
i'm not stock height... my car is pretty slammed... by three fingers... i meant I'm about an inch off the ground... so 25mm for fronts and back?
Old Apr 12, 2009 | 06:47 PM
G35_sylvi's Avatar
Originally Posted by gr8huntr
u should be able to go 25mm spacers , a real good kind are ichiba's ....good luck
ty!!!
Old Apr 12, 2009 | 07:12 PM
gr8huntr's Avatar
Those are Ichiba spacers Version 2 25mm should have clarified that sooowwy
Old Apr 12, 2009 | 07:22 PM
eurodre's Avatar
ichiba v2 spacers, pm the vendor b2autodesigns good prices n fast shipping
Old Apr 13, 2009 | 01:31 AM
SuperStezzyG's Avatar
I have the same q but I'm running 19x10(275/45) +20 on a coupe I was wondering if I should
Run an 10mm or 15mm so I can be flush with the fender I'm running H-tech 350z
Old Apr 16, 2009 | 11:49 PM
G35_sylvi's Avatar
so would 20mm front and 25mm be good for me or should i go 25mm all the way around??
Old Apr 16, 2009 | 11:54 PM
str8dum1's Avatar
dont you own a ruler? you do realize you can measure the exact distance of how ever flush you want them to be
Old Apr 17, 2009 | 12:14 AM
G35_sylvi's Avatar
the wheels aren't on my G yet. waiting for them to get some tires put on... LOL I wanted to figure out what I wanted so that I could order them and not have to wait til after i put the wheels on...
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
