Volk GTS/Challenge offset/lipsize comparison
Old Apr 16, 2009 | 01:08 PM
nyckid's Avatar
Here's the chart for the GTS
Here's the chart for the SF-Challenge
Which lips would be bigger... when comparing the volk gts in a 19x9.5 +17 / 19x10.5 +28 (Yes I mean +28 and not +18) to the volk sf-challenge at 19x9.5 +28 / 19x10.5 +23?
If I am not mistaken by reading those 2 charts, it looks like the rear lip on the challenges is the same size as the front lip on the gts. Which is 94mm (3.7inches)
Old Apr 16, 2009 | 03:09 PM
redlude97's Avatar
gts rear
Old Apr 16, 2009 | 06:34 PM
nyckid's Avatar
thanks redlude... do you know if the 19x10.5 +28 volk gts will flush with my rear fenders? nobody has this setup as far as i know and i am dying to see pictures to see how far or how inward the wheels+tires would sit before making a purchase.
Old Apr 16, 2009 | 06:42 PM
kilo's Avatar
these are +28 and this is how they would look...car is on stock suspension.
Attached Thumbnails Volk GTS/Challenge offset/lipsize comparison-picture-027.jpg
Old Apr 16, 2009 | 06:51 PM
redlude97's Avatar
not even close to flush
Old Apr 16, 2009 | 08:36 PM
nyckid's Avatar
kilo, appreciate the picture. do you have anymore photos from different angles? it looks pretty flush to me...
Old Apr 16, 2009 | 08:47 PM
Skaterbasist's Avatar
Retired SuperMod
+28 on a 10.5 will not be close to flush. Trust me, I have +18 on a 10.5 and I can barely consider it flush (its not too aggressive either).
Old Apr 16, 2009 | 08:56 PM
nyckid's Avatar
well from looking at that picture that kilo posted, it doesn't look so bad? but then again its not dropped... however i want to see it from different angles so i can make a better judgement.
do you guys think its that bad from that picture?
Old Apr 16, 2009 | 09:11 PM
redlude97's Avatar
no fender roll=tucked
Old Apr 16, 2009 | 09:25 PM
nyckid's Avatar
what if i add a 10mm spacer, then will it be the same flushness as if i were to have gotten the +18 offset instead? i know the lip will be slightly smaller, but as far as flushness it should be the same?
i guess it's a matter of preference... ive seen a lot of setups on here with the tucked look as well...
Old Apr 16, 2009 | 11:07 PM
Retired SuperMod
If you have any plans on doing 10mm spacer on the +28, why not just go with the +18 offsets? And you'll get the nicer lip.
Is there a reason why you are avoiding the +18 rear offsets?
If you insist on the +28's, I would do a 15mm spacer for the rears.
Old Apr 17, 2009 | 12:48 AM
nyckid's Avatar
i guess it's because i don't want anything too aggresive looking? I don't really like the look of the tire+rim sticking out of the fender. I either like it flushed or sit a little bit in from the fender. I'm not going for the crazy extreme aggressive look i don't think. I am still in the process of deciding.
Will you be able to fit a BBK on the rears with a +28 offset?
Old Apr 17, 2009 | 12:53 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The +18 is FAR from aggressive, even with a 285 tire, especially on the drop you have. The +28 would be grossly tucked.
-GP-
Old Apr 17, 2009 | 01:05 AM
Triple8Sol's Avatar
Given same specs, the GT-S will always have a bigger lip. Hopefully your decision is based on more than just lip size, though. Having owned several sets of both wheels, I love them both in different ways.
If you're buying the GTS, go with +17/+18 (unless you're custom ordering, then go more aggressive). If buying the SF-Challenge, go with +21/+23 (again, unless custom ordering).
Old Apr 17, 2009 | 01:51 AM
nyckid's Avatar
triplesol, if you were to go aggressive with the gts and challenges and get them custom ordered, what offset would you go with your g35 coupe?
i like aggressive too, its growing on me the more i look at it, but am too afraid of getting offsets that most people on here aren't using. i just want to be on the safe side by sticking to the most common offsets that everyone's using.
