why not to use an impact wrench to put on wheellocks or lugs?
Old Apr 20, 2009 | 05:45 PM
  #31
Jeff92se's Avatar
Red Card Crew
I weighed 135lbs once. But then I entered the 8th grade. lol.
Old Apr 20, 2009 | 05:49 PM
  #32
GEE35FX's Avatar
haha, as long as you aren't trying to attain Sumo weight
Old Apr 20, 2009 | 06:00 PM
  #33
NaiveRapture's Avatar
80 Ft/lbs is hard to reach? Jesus when I use my tq wrench I'm always like "that's ALL? I feel like they should be WAY tighter but... guess not.
Old Apr 20, 2009 | 06:03 PM
  #34
redlude97's Avatar
Originally Posted by GEE35X
Ouch, if most people tightened them that tight there would be a few stripped studs around and lots of over-torqued wheels. 80ft-lbs is not very tight.
My torque wrenches are as handy as my sockets and other tools so I always use it.
Heck on my Z71 truck the torque for the wheel studs is 140 ft-lbs instead of 80 ft-lbs for our G35s, that is a huge difference.
Just to clarify, this is with either the OEM socket or a normal 3/8" wrench. I have set 80 ft/lbs with a torque wrench multiple times and have a pretty good feel for it. I have never stripped a stud or IMO overtorqued a wheel. Not like the way an impact wrench has anyways.
Old Apr 20, 2009 | 06:05 PM
  #35
redlude97's Avatar
Try to get 80 ftlbs on a 3/8" 12" long breaker bar. You'd have to stand and jump on it (if you didn't break it first).
A 1/2" 24" bar is alot easier to get that but there's still a decent amount of force needed to get to that.
On my maxima, the front CV joint bolt needs about 160-ish ft lbs. I had to use a 3/4", 24" long breaker bar with long arsed cheater pipe to get that
LOL I'm surprised you would admit to that old man
Old Apr 20, 2009 | 06:11 PM
  #36
Jeff92se's Avatar
Red Card Crew
The only real way to strip a stud/nut is to use an impact w/o hand starting the lug. I usually put the lug into the socket and thread it down most of the way for the 1st two (so the wheel sits against the hub. Then hand start the others for 4-5 turns to make sure it's started right.
BTW. I take my old measurements back. My 1/2" breaker is about 14". Same as GEE35X.
My 3/8" drive is about 8-10"?
But my old torque wrench is at least 14"-18". So 80ftlbs is easy. It's supposed to be. You're not supposed to have to struggle to get a xx ftlb measurement. It will end up being inconsistent.
magnetism80
Feb 1, 2019 10:00 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
mikemf8
Sep 3, 2015 08:01 PM
