I was installing my sway bars today and ran into one problem. The nut on the drivers side would not come loss.Try as i may that sapsucker would not move. The one in the rear went on perfect. Now i have to go buy a nut buster to install the front tomorrow .So that i can take the front sway bar off. I will have pics. tomorrow.
From me to U suck my exhaust
2003 6Mt
Val 1,Stillen slotted rotor,Injen cai,Double din,Memphis SHP 10',(Hotchkis Sway Bars and Tein Lowering Springs on the way)
2003 6Mt
I've been so lucky, when I can't break something like that, I call my brother, he's got one of those air impact wrenchs that puts out like 550ft lbs of torque. On mine, when I installed my Cusco bars I had to use a long handled box end wrench and I used my leg to shove on it real hard, that did the trick.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
It is all about leverage. Unfortunately, when you don't have much space to do it, then it becomes a real problem. You can try spraying WD-40 on it and see if that helps. I was fortunate to change my sway bars at a friend's house that has an air wrench. That sucker took it out in a heart beat.
2004 G35 Coupe/OB/Graphite interior/Premium and aero package/Popcharger/Z tube/Hotchkis sways/Tein H-tech springs/Kinetix plenum/Crawford cats
I have never seen someone change, add or modify a sway bar, but if you're having a problem with removing a nut or bolt, try either adding or removing heat. Most things expand when heated. Heat a nut and then try to loosen it. Freeze a bolt and try to loosen it. Those are 2 tricks that haven't been mentioned yet... Good Luck.
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Need some advice on these bars. Do they fit both the sedan and coupe using the same Hotchkis part number? Reason why I'm asking is because I want to use them on my sedan and once I give my car back after lease, I want them to be put on my GF's coupe. Thanks!
Do these bars come with the end links as well? Do I have to get new end links or buy anything else to have them fit? Thanks!!
It's still a G thang!!
Rumble, it's the same part number, all Z and G sway bars are all the same, oem and the aftermarket one's. You do not need to buy anything else as either the bars will come with new mounting bushings or will reuse the oem bushings. All bars reuse the oem end link system.
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
spray some PB blaster (yes this stuff works) and use 2 wrenches to get more leverage. You know how to interlok 2 wrenches don't you.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
AIM= bkchang79
Rear Say
[image]C:\Documents and Settings\MILLS FAMILY\Desktop\DE MP3\Picture 073.jpg[/image]
Frt Sway
[image]C:\Documents and Settings\MILLS FAMILY\Desktop\DE MP3\Picture 072.jpg[/image]
Rear Med.
[image]C:\Documents and Settings\MILLS FAMILY\Desktop\DE MP3\Picture 074.jpg[/image]
Frt Soft
[image]C:\Documents and Settings\MILLS FAMILY\Desktop\DE MP3\Picture 075.jpg[/image]
Hope This Works
2003 6Mt
Frt Sway
Rear Med.
Frt Soft
Hope This Works
2003 6Mt
ahhhh!! hello or something.....(butthead voice)
dude, like you are trying to show us pictures that are inside your computer hahaahahahaaha!!!
Gsedan35 > Cool...thanks for the answers, thats exactly what I needed to know. You da man!!
One more thing...where is the cheapest place anyone has picked this part up from? Thanks!!
Titan Motorsports had them for $250 shipped back in Mar-Apr...dunno now.
$250 shipped? Cool. Anyone, anywhere else?
From what I read on the forum, these are the best sways for the dollar. What are ur thoughts?
what the? interlock 2 wrenches? never heard of it. how do you do it?
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
In any event my350z has two sway bar change out how to's that are excellent.
Edmund Burke
G35 6mt
Edmund Burke
G35 6mt
Installing the sways should be easy and all the parts to install it are already included in the box.....here is a pic.
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
