Eibach Sways and Tire Pressure Monitors
Old Jul 7, 2004 | 07:12 PM
sux2bu's Avatar
I just had my Eibach Sways installed by a local peformance shop. About 30 seconds after I left the shop, my low tire pressure indicator displayed. Does anyone know if their is any correlation between the sway install and display of the indicator? BTW, I was advised by the shop that they did not have to remove any of the wheels to complete the sway install.
On a seperate note, after the install I hear a popping noise when turning. I was advised that this is normal because the bushings are stiffer than oem and I will probably hear this until the bushings are fully broken in (btw, lubricant has been used) - Does this sound correct?
Thanks.
JWT Pop-Charger/Z Tube * Clear Corners
20% Tint * HyperGrounding Kit * Iforged Evo's
OEM Chin Spoiler * Kinetix Plenum (on order)
Old Jul 8, 2004 | 08:37 AM
Catatafish's Avatar
Re: Eibach Sways and Tire Pressure Monitors
According to my service manual, If the light comes on and you hear a sound, you have a tire less than 28 psi. If the light comes on and you don't hear a sound, there is a malfunction of the sensor.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats/ Service Engine Soon
Old Jul 8, 2004 | 11:08 AM
sux2bu's Avatar
Thanks for the information. After checking my tire pressure, I realized that tire pressure was low in all four tires. I am not certain why tire pressure was sufficient prior to the shop visit and insufficient thereafter. As for the popping noise while turning, I have not heard it after putting air in the tires.
jsimonk
Dec 22, 2023 03:49 PM
JoeMac
Aug 20, 2015 10:17 AM
wuppiedog
Aug 7, 2015 11:16 AM
