Question for tire size - g35 coupe
hi redlude 97:
Do you know if I have back tires 245/35/R19 then what should the correct fronts be?
I have to get my falkens this week and make sure I get the right tire sizes.
my defaults Bridgestones are these:
225/40/19
245/40/19
then I got Falkens in these sizes:
fk 452
front 225/35/19
rear 245/35/19
These did not last me over 9 months I think it was. Now the front tires are bad.
So my question is what is the best tire size you recommend for the fronts now.
I want to change them to the correct size and make sure it doesnt throw off my cars performance.
Another question is do you think everytime changing new tires you need a alignment?
I was told the tires popped so fast is because my alignment was off and it rub off the side of the tires faster then the rest so hit the metal of tire faster.
If you can give me any advice I would really appreciate it! thanks!
IF ANYONE ELSE CAN HELP ME ANSWER THIS QUESTIONS THAT WOULD BE COOL TOO! THANKS!
225/40/19
245/40/19
fk 452
front 225/35/19
rear 245/35/19
depends what you're lowered on... I'm running 245/40/19 on all fours and im lowered on DF210 w/ NO spacers and i rub a little bit when the steering wheel is fully turned and go up a bump fast. Tires are Goodyear RS-A just for reference.
I disagree. Using a taller tire in the front will shift the balance of the car to the rear and raise the front of the car ~1/4" while also changing the circumference of the front wheel, which will again, also affect the performance. I recommend using a 245/35/19 in the front paired with a 245/40/19 or 255/40/19 rear, which Falken does make in the 452 lineup.
