Prothane Sway Bar Bushings
Old Jul 13, 2004 | 10:30 PM
360Iron's Avatar
Has anyone had experience with the Prothane sway bar bushings on the stock bars? (They are listed on Prothane's site as 350Z sway bar bushings) It seems like just making this change could limit roll significantly. Any feedback would be appreciated. Especially anyone who has tried these and then gone to aftermarket bars.
Tom
Old Jul 14, 2004 | 09:15 AM
Q45tech's Avatar
Re: Prothane Sway Bar Bushings
Anti Roll /sway bars are not really as stiff as springs so don't use them to try to limit body roll beyond 40% of springs...........they are primarily a fine tuning tool.
Bushings primarily work in the first inch of body [out of the 3.5" design] roll to isolate the car from street bumps and rough road vibrations.
A better procedure is a stiffer bar with soft bushings for the street.
Old Jul 15, 2004 | 01:07 PM
360Iron's Avatar
Thanks for that insight. But I noticed that all of the after-market sway bar kits have polyurethane bushings. Do some kits come with lower durometer bushings? Or a selection of bushings? I really want to avoid machining my own parts. Do you know what the typical durometer of stock bushings would be?
While I have your attention, I noticed that you have had a lot of input on tires and I have read your posts with great interest. I have posted a tire question: “Upgrading Sedan Tires on Stock Rims” that I would appreciate your input on.
Tom
Sedan 6MT, Sport and some other usless options
Searching for the value engineered suspension...
Old Jul 19, 2004 | 06:37 PM
jdove's Avatar
THe 350EVO sways ceom with bushings other than Urethane. They are firm and are very quiet. Urethane on the other hand must remian lubricted or they will squeek. I use the 350EVO sways and they are great fro street and track use.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
