19x8 front?? handling? ride quality?
Old May 19, 2009 | 03:42 PM
sinasajadi's Avatar
hi everyone I have a quick question. how is the ride (handling) with the 19x8 fronts. in other words why would one prefer a wider wheel up front? would the 19x8 be less desirable for most? sorry if this is a newbie question.
I am thinking about purchasing a set of DPE wheels which are 19x8 and 19x10 rear.
I have an 06 coupe with sport suspension. and oem 19's now.
thanks to anyone who can chime in.
Old May 19, 2009 | 03:59 PM
redlude97's Avatar
as long as you use a 245/35/19 tire on there it will be fine. its not a optimal size, but its manageable
Old May 19, 2009 | 06:02 PM
sinasajadi's Avatar
thank you for the response. but, by "optimal" what do you mean? why would someone stray away from a 19x8 front wheel? why is it undesirable?
sorry if I am being a little too ****.
Old Jun 11, 2009 | 09:20 PM
hyunkoon's Avatar
I have 18X9.5 with 275/35/18 in front.
Comepare to the stock, it is much much stable and handling is superior.
Old Jun 12, 2009 | 12:46 PM
redlude97's Avatar
An 8" wheel is the minimum width acceptable for a 245/35/19. The tire will bulge a bit past the wheel, and will be slightly squirmier than the same tire on a wider wheel such as a 9/9.5", which is why it isn't optimal.
Old Jun 14, 2009 | 03:02 PM
pwebb's Avatar
225/40/19 should fix that
Old Jun 14, 2009 | 03:22 PM
redlude97's Avatar
That is just a poor size to run when combined with any tire you use on a 10" wheel in the rear though. The car will understeer like crazy
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Th611
Oct 27, 2015 03:48 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
