Performance plus brakes!! If your looking for brak
#31
#33
Re: Performance plus brakes!! If your looking for brak
I'm not changing brakes on my car untill warranty expires.
From all they are offering I would only maybe try the slotted ones but would stay away from drilled or drilled/slotted. Last two take too much away from the weight of the rotor and this is what dissipates heat.
On my 240 I had to literally STAND on the pedal and still not being able to lock 205 tires with drilled/slotted setup after 20 minutes of downhill. Cold bite was awesome though. My advice stay with blank rotor, if you want some looks - slotted max, and just use great pads. I like Hawk HPS for the street the best.
Those are my PERSONAL suggestions and observations. Results may vary.
***04 G35s 5AT/Sport***
***04 Volvo XC90 T6***
#34
The drilled are like slotted, they are not drilled all the way through. For this price it might be worth buying a set for the future. You wont find this price again! I didnt think they would be any bigger, how would they be? Wouldnt the caliper bracket have to also be bigger? The Caliper is fixed to the mount.The mount would have to go up in size also.
#36
#37
#42
I AM IN!. I spoke to these guys two weeks ago and I requested black, and they said no problem. I just want the final price. Actually, I did not even know you had this group buy thing going on. I was considering these rotors long time ago. My only problem was I could not understand why they were so cheap to those found at Stillen.com for example.
