19 VS 20 Inch Wheels
Old Jun 17, 2009 | 02:33 PM
only1waqas's Avatar
I wanted to get 19inch wheels for the longest time but then i ran across these 20inch that i really like...
are there any major differences between 19" and 20"? Im currently lowered on Tein S tech...will it rub?
Specs of the wheels are
Sevas S22
Fronts are 20x8.5 offset 25
Rears are 20x10 offset 40
Does Gas Mileage play a roll if i go to 20inch, i know it might sound like NOOB question but just wondering.
thanks.
Old Jun 17, 2009 | 05:56 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Won't really see/feel a big difference. If any, the 19's might ride better the 20's will handle better, but that's splitting hairs. Bigger diff between 18 and 20 than 19/20.
Old Jun 17, 2009 | 06:09 PM
only1waqas's Avatar
thanks neal what tires should i run?
Old Jun 17, 2009 | 06:17 PM
Jeff92se's Avatar
Red Card Crew
Either way is fine but man, I'd be scared to run Sevas right now.
Old Jun 17, 2009 | 06:18 PM
GMoNeYAir23's Avatar
245/35/20 and 275/30/20, is what I'm running right now.
Old Jun 17, 2009 | 06:24 PM
cremaster's Avatar
40 series on a 20inch wheel? damn, must look huge.
and +1 on jeff's comment.
Old Jun 17, 2009 | 06:39 PM
only1waqas's Avatar
I heard about what happened to anotehr member G's....I like the style of the S22.
im double minded now...lol
Old Jun 17, 2009 | 06:42 PM
KSWAY's Avatar
I'd like to see pics of the 40 series on 20's.
Old Jun 18, 2009 | 10:15 AM
PLATINUM SPONSOR
Really depends on the wheels you end up with. Offset and width will play a lot into what will fit or not fit.
Old Jun 18, 2009 | 11:32 AM
Sorry, I completely messed that up..I'm running 245/35 and 275/30, I don't know what I was thinking.
I edited post above.
Old Jun 18, 2009 | 05:12 PM
Skaterbasist's Avatar
Retired SuperMod
What do you mean are there any major differences between them? Im guessing you are referring to the impact in performance?
Physics tells you you will be slower with 20's. Though it really depends on how much the differences in weight will be (assuming they are the same wheel, the 20's will be heavier than their 19's counterpart).
I probably wouldn't consider it a major difference, but with 20's, you will be slower and have a slightly rougher ride.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
realtalk21
Jul 20, 2015 09:07 AM
Soumilg
Jul 18, 2015 12:33 PM
