Wheel Spacer Question
Old Jun 25, 2009 | 02:23 AM
jattg35's Avatar
I have a 2004 sedan and I am putting on the stock sport 18 sedan wheels from a 2005 model. I was wondering what size spacer I would need for a aggressive look. The tire size is 245/40/18. Pictures would be awesome help as well. thanks.
Old Jun 25, 2009 | 09:16 AM
TurTLe*'s Avatar
not sure what the offset is for the stock 18's, my track wheels are 18x8 +30 and 18x8.5 +33mm, and that brings be pretty much flush. Not sure what your idea of agressive means. some mean flush and some mean a little on the low rider side.
find out your offset on the 18's and then try to aim for +33 to 35.
like say stock 17's are +45, you would want about a 10/15/20mm spacer to bring it flush. If you want a semi staggered look go with 10mm fronts and 20mm rears.
I assume stock 18's are near +45. so 10mm fronts and 20mm rears.
Old Jun 25, 2009 | 10:32 AM
Johnnyone's Avatar
"18" 5 split spoke (2005+ Sedan optional)
Front & Rear: 18"x7.5" (+45mm)"
From: https://g35driver.com/forums/wheels-...s-offsets.html
Old Jun 25, 2009 | 11:08 AM
TurTLe*'s Avatar
^ 18x 7.5 changes a bit. maybe F15mm and R 20/25mm
I thought it was 18x8
Old Jun 27, 2009 | 06:40 PM
jattg35's Avatar
so I should do a 15mm in the front and a 20 in the back? where do u recommend buying them?
Old Jun 27, 2009 | 06:53 PM
Blue Dream's Avatar
I drove ttrank's car solo
Are you sure on those tire sizes? The 05 sport sedan wheels came with 235 45 18's.
Old Jun 27, 2009 | 06:56 PM
b2autodesigns's Avatar
I would recommand doing 15mm front and 20mm rear. Alot of customers with sedan applications have bought this size.
I have the Ichiba v2 spacers in stock. They are a direct bolt on. Takes 1-2 days to your door. $230.00 shipped for 2 sets. Let me know.
Here is a link where you can check them out.
https://g35driver.com/forums/wheels-...-5mm-25mm.html
Thanks
Charles
Old Jun 27, 2009 | 08:39 PM
KevcoG35's Avatar
Right now I am running 245 40 18's on my oem sport rims and 20mm spacers all around. Fronts are PERFECT, back passenger rubs like crazy on the fender lip. Be prepared to roll the fenders on 20mm + in the rear. BTW I'm lowered on Z suspension as well.
Old Jun 27, 2009 | 09:24 PM
6MTFTW's Avatar
https://g35driver.com/forums/media-s...hotoshoot.html
Sedan sport wheels with 20mm spacers all around and 245/40/18. That's my old setup.
Old Jun 28, 2009 | 12:46 AM
jattg35's Avatar
the stock tire side is 235/45/18 but im going with 245/40/18.
and i will definately keep those spacers in mind.
i think i like the way the 20mm looks all the way around.
Old Mar 30, 2010 | 01:23 AM
jattg35's Avatar
bringing this back alive!
im looking at buying a set of 15mm all around. maybe 20mm if dont hav to roll my fendors and i wont rub. im going to be dropped on tein basics btw if that makes a difference. but should i get the ones with the built in studs or the other ones? does it make a difference? any suggestion on a brand or where to buy em from? thanks.
Old Jun 24, 2010 | 03:49 PM
inda626's Avatar
spacer advice please
Going back to my oem 18 7 spoke... Need advice as to what size spacers to run?? I am lowered on Tein cst (350z) coilovers, but not slammed. Rear fenders were rolled by "ShanesG", nicely done. Just not sure what to run.. 20f&25r, or 25 around, or ??? Any help would be great, Thank you..
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
